Different setting between version 14 and 2017
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I already create simple model of version 14 and 2017 .
version 14 is OK .
version 2017 is fail.
I already compare in FEM file.
I found SPC control card  have set F  in Ver. 2017.   (ex. SPC            1    2922  123456   F)
but  0.0 in ver. 14                                                       (ex .SPC            1    2922  123456   0.0   )
I' m sure what is problem for this situation . but when i change F to 0.0 , the result is OK .
Could you please tell me how to solve this problem instant  change manually .
1 - 11 of 111
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Maybe a bug of Optistruct's FE output template?
    Altair Employee
    OP
    Hi,
    I tried in Student edition and also on commercial version of 2017. I am not able reproduce this issue.
    Do you have any continuation subcases in your model?
    User: "tinh"
    Updated by tinh
    Could you edit card an SPC and confirm value after 123456 is F or 0.0?
    Altair Employee
    OP
    @Prakash  NO. just  1 subcase
    Altair Employee
    OP
    yes , I must edit this value . but i  am not understand when i do the same method with version 14  i don't found this problem.
    Altair Employee
    OP
    Hi,
    Hi ,
    I try many but i found same problem . i just set T joint and fix constraint 2 way  and applied force 1 other way .
    so I just set 1 subcase
    Altair Employee
    OP
    Hi @sagpichest
    You get this because Fixed option is checked in constriants panel. Uncheck it and try again.
    User: "tinh"
    Updated by tinh
    @sagpichest:D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' /> do not fiddle with anything you don't know
    Hi @Prakash Pagadala , what is 'fixed' option used for? I didn't find it in Optistruct reference guide v14
    Altair Employee
    OP
    @tinh
    SPC with Fixed is used in relation with CNTNLSUB for nonlinear subcase to retain deformed boundary from previous subcase.
    If you try to run when SPC is defined with fixed ON, OptiStruct fails with an error.
    Altair Employee
    OP
    @tinh
    This is different point between V14 and 2017 right ?
    because i don't see this function in V.14
    thanks and best regards,
    Sagpichest S.
    Altair Employee
    OP
    Hi @sagpichest
    Yes. Fixed in constraints panel is not available.
