Altair RISE
Nominate Yourself Now!
Topic Modelling with LDA
User: "Ilyas"
New Altair Community Member
Updated by Jocelyn
Hi Guys,
How do I set up a process with LDA to do topic modeling, please? I placed the LDA operator to process window, but don't know how to import word files into it.
1 - 23 of 231
    User: "Marco_Barradas"
    Altair Employee
    Accepted Answer
    Ilyas,
    You basis setup would be a Loop Files (To grab all your documents) with a Read Document inside of it.
    The (?i).*docx tells the operator to only use the files that have a docx extension
    <?xml version="1.0" encoding="UTF-8"?><process version="9.9.002">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="-1"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="concurrency:loop_files" compatibility="9.9.002" expanded="true" height="82" name="Loop Folder With Files" width="90" x="179" y="85">
            <parameter key="filter_type" value="regex"/>
            <parameter key="filter_by_regex" value="(?i).*docx"/>
            <parameter key="recursive" value="false"/>
            <parameter key="enable_macros" value="false"/>
            <parameter key="macro_for_file_name" value="file_name"/>
            <parameter key="macro_for_file_type" value="file_type"/>
            <parameter key="macro_for_folder_name" value="folder_name"/>
            <parameter key="reuse_results" value="false"/>
            <parameter key="enable_parallel_execution" value="true"/>
              <operator activated="true" class="text:read_document" compatibility="9.3.001" expanded="true" height="68" name="Read Document" width="90" x="246" y="34">
                <parameter key="extract_text_only" value="true"/>
                <parameter key="use_file_extension_as_type" value="true"/>
                <parameter key="content_type" value="txt"/>
              </operator>
              <connect from_port="file object" to_op="Read Document" to_port="file"/>
              <connect from_op="Read Document" from_port="output" to_port="output 1"/>
              <portSpacing port="source_file object" spacing="0"/>
              <portSpacing port="sink_output 1" spacing="0"/>
              <portSpacing port="sink_output 2" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="operator_toolbox:lda" compatibility="2.11.000" expanded="true" height="124" name="Extract Topics from Documents (LDA)" width="90" x="380" y="85">
            <parameter key="number_of_topics" value="10"/>
            <parameter key="show_optimization_settings" value="false"/>
            <parameter key="use_alpha_heuristics" value="true"/>
            <parameter key="alpha_sum" value="0.1"/>
            <parameter key="use_beta_heuristics" value="true"/>
            <parameter key="beta" value="0.01"/>
            <parameter key="optimize_hyperparameters" value="true"/>
            <parameter key="optimize_interval_for_hyperparameters" value="10"/>
            <parameter key="iterations" value="1000"/>
            <parameter key="top_words_per_topic" value="5"/>
            <parameter key="stopword language" value="english"/>
            <parameter key="reproducible" value="false"/>
            <parameter key="enable_logging" value="false"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
            <parameter key="include_meta_data" value="true"/>
          </operator>
          <connect from_op="Loop Folder With Files" from_port="output 1" to_op="Extract Topics from Documents (LDA)" to_port="col"/>
        </process>
      </operator>
    </process>
    User: "Ilyas"
    OP
    Accepted Answer
    Thank you, Marco. I tried, but couldn't get it to run (see below).
    I am trying to run topic modeling for interview transcripts. The original transcript files are 'Text Document'. Would it be easier to run LDA with that?
    Altair Employee
    Accepted Answer
    Updated by Marco_Barradas
    Ilyas,
    Just adjust the filter by regex string on the parameters or remove it if you only have he file you need at that folder.
    The error that is shows is telling me that there are no files with the .docx (Word Document) on your folder. If your files are .txt (Text Files) just change the .docx to a .txt
    If you need further help please type and @ and my name and I'll receive an e-mail alert with the latest update on your post.
    User: "Ilyas"
    OP
    Accepted Answer
    @MarcoBarradas,
    Thank you again for the direction. I can't get the Loop Files operator to see txt files. Could you please help?
    In summary, I still cannot make the process run. I have 10 separate txt files (for the 10 interviews I conducted). I also have a combined single txt file for all the interviews. Which one is best to use; individual txt files or a single large file?
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi,
    can you just try
     as regex? That takes every file no matter how its called.
    Best,
    Martin
    User: "Ilyas"
    OP
    Accepted Answer
    Hi Mschmitz,
    Thank you. I got the below error. I wonder if I am using the wrong operator. I took the 'Loop Files' operator and renamed it 'Loop Folder with File'. Would this cause an issue?
    Altair Employee
    Accepted Answer
    Hi,
    no. you propably did not connect the output of your read operator in the loop files correctly. Can you maybe post the process XML?
    Best,
    Martin
    User: "Ilyas"
    OP
    Accepted Answer
    Sorry, I don't know how to post process XML. Please see .rmp file attached.
    Altair Employee
    Accepted Answer
    Hi @Ilyas ,
    rmp files are nothing else then XML files. So you posted the right thing. You can open the XML panel to make the export easier, but thats a minor thing.
    Attached is an updated process. You had no operator within the Loop files which then actually reads the files. I added Read Document for txt files.
    Best,
    Martin
    User: "Ilyas"
    OP
    Accepted Answer
    I managed to import my interview transcripts to Local Repository. See top left below.
    Altair Employee
    Accepted Answer
    In this case you can just drag and drop them in and use an Append operator to merge them into one data set.
    User: "Ilyas"
    OP
    Accepted Answer
    @mschmitz Thank you Martin.
    I am finally making progress.
    My first file in the Local Repository (All Transcripts Combined) includes everything. That is all I need to use. So can I do the below?
    Altair Employee
    Accepted Answer
    Hi,
    you can remove the loopfiles in this case.
    Best,
    Martin
    User: "Ilyas"
    OP
    Accepted Answer
    Do you mean to remove all the other individual text files from the local repository?
    Altair Employee
    Accepted Answer
    no, just the loop files operator in your process.
    User: "Ilyas"
    OP
    Accepted Answer
    But it does not like it. Please see below.
    Altair Employee
    Accepted Answer
    There are two different LDA operators. You want to use the other one, called Extract Topics from Data.
    User: "Ilyas"
    OP
    Accepted Answer
    Thank you, it worked!
    In the text attribute parameter (top right) I put in Text and it did not work. 16:07:44 Go. was already there and it works with that. Is the below okay now please?
    Altair Employee
    Accepted Answer
    Hi,
    if the column holding the text is called 16... Go, yes.
    Best,
    Martin
    User: "Ilyas"
    OP
    Accepted Answer
    My next challenge is to understand the results. How do I name the 10 topics from the results, please?
    Altair Employee
    Accepted Answer
    Hi,
    have a look at the 2nd output of the operator. It contains the top words associated which each topic.
    Best,
    Martin
    User: "Ilyas"
    OP
    Accepted Answer
    Am I correct in saying that weight means the number of times a word appeared in the document? For example, think:180, digital:125, etc...
    Altair Employee
    Accepted Answer
    Yes,
    i am actually not sure if it is the actual sum or with some weights and things, but this is how you can interpret it.
    BR,
    Martin
