Altair RISE
Nominate Yourself Now!
Need guidance for Modeling and Preparation Datasets is given
User: "Atilla"
New Altair Community Member
Updated by Jocelyn
Dear Community,
just started to get confi with rapidminer (absolute beginner)
I´ve tried to build a process mainly focused on labeling target attribute, detecting outliers, missing values.
In the end I should be able to build a model which can predict wine quality
therefore I need to build a baseline classification with training and test data
The modell should be improved in the end and evaluated
I am really stuck in the preparation process.
For further details please have a look at my processes and lecture sheet.
I would be greatefull for any hint or guidance
Best regards
Atilla
1 - 5 of 51
    User: "Caperez"
    Accepted Answer
    I review your process. there are some redundant operators but in general good work. I don't know where are you stuck. you removed the noise, missing values and reduced the label to three values.
    Best
    User: "Atilla"
    OP
    Accepted Answer
    Thank´s for your review I apprecite it. Now I finished it with modelling and testing. Would you keen to have a look on that process? Are they mistakes or redundancies?
    Kindley Regards
    User: "Caperez"
    Accepted Answer
    Hi @Atilla
    Without the excel file I can't run the process. however, looking at process I can see that you are using a Select Attributes operator and you are selecting all of them, It's no necessary. also you are using a Set Role Operator, after Select Attributes, with the label attribute but assigning it a regular role, for then assigning it a label label role into the Cross Validation Operator. you can remove the first Set Role Operator
    Best
    User: "Atilla"
    OP
    Accepted Answer
    Awesome thank you. By the way, here are the excell files.
    User: "Atilla"
    OP
    Pardon me, this is the right excell-file >
