Altair RISE
Nominate Yourself Now!
Clustering and writing back results into MySQl Database
User: "ash1998"
New Altair Community Member
Updated by Jocelyn
Hi
i am making Text clustering and i got 5 clusters with text.
So i want write back into the MYSQL Database to each. Im not sure where to connect the write database.
For example.
t1 is cluster 1
t2 is cluster 2
t3 is cluster 3
So i have a new Column in my table and every data should get a cluster.
Regards,
Ash
1 - 5 of 51
    Hi,
    just remove the cluster Visualizer. The blue output of clustering has all the information you wand.
    Best,
    Martin
    User: "ash1998"
    OP
    Hello, i have try that. and i got error.
    Hi,
    try the other output port of clustering, that should work.
    Best,
    Martin
    User: "ash1998"
    OP
    Now it says too many column. I am running this in local repository.
    Hi,
    likely you have hundreds or more columns from the Process Documents. Most databases have a max limit on it. I would use Select Attributes and only select id and cluster to go ahead.
    Best,
    Martin
