🎉Community Raffle - Win $25
Join and Win
I want to copy data from one column into another column of same dataset. What operator to use
User: "Somnath_Das"
New Altair Community Member
Updated by Jocelyn
I do not want to create a new column using generate attribute.
1 - 4 of 41
    why not Generate Attribute? Its usually good.
    Otherwise - there is a Generate Copy operator.
    Best,
    Martin
    User: "Somnath_Das"
    OP
    I don't want to create unnecessary fields and then again have to remove them using select attribute. Have checked Generate Copy but that is alo creating a new column. Am not able to copy the data from one column to another
    User: "BalazsBaranyRM"
    Accepted Answer
    Hi,
    you can use Generate Attributes and just enter the name of the attribute you're overwriting. This won't create a new attribute but work on the existing one.
    Regards,
    Balázs
    Hi,
    then I do not understand what you want to do, can you maybe give an example?
    Best,
    Martin
