How can we re-order the elements in one list with respect to other list?
Hi All!
I have a data set that has 5 columns. the first column is the ID and all other columns have concatenated data. so, I just reorder one column with respect to another column based on common values also.
here ch_1 is having terms and their respective values are present in va_1 in the same order and also the same for ch_2 & va_2.
ch_2 terms having their values in va_2.
if we change the order of terms in ch_1&ch_2, values order also should change in values columns va_1&va_2.
source data:
no ch_1 ch_2 va_1 va_2
123 sh|;ty|;hi hi|;sh 8|;"cir"|;89 98|;8
required output:
123 sh|;hi|;ty sh|;hi 8|;89|;"cir 8|;98\
if we split the data based on separator we may have source data differently
after twisting the source data:
123 sh hi 8 98
123 ty sh cir 8
123 hi ? 89 ?
here also how can get the same order for both ch_1&ch_2 and respective va_1&va_2 should also be changed.
output required:
123 sh sh 8 8
123 ty ? cir ?
123 hi hi 89 98
can anyone help to solve this either with source data/ twisted data?
Thanks in Advance!
source data:
required output:
123 sh hi 8 98
123 ty sh cir 8
123 hi ? 89 ?
output required:
123 sh sh 8 8
123 ty ? cir ?
123 hi hi 89 98
Thanks in Advance!
1 - 1 of
11
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process">
<parameter key="logverbosity" value="init"/>
<parameter key="random_seed" value="2001"/>
<parameter key="send_mail" value="never"/>
<parameter key="notification_email" value="yhuang@rapidminer.com"/>
<parameter key="process_duration_for_mail" value="1"/>
<parameter key="encoding" value="UTF-8"/>
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.9.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="34">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="no ch_1 ch_2 va_1 va_2 123 sh|;ty|;hi hi|;sh 8|;cir|;89 98|;8 126 sd|;tf	 hi|;sh|df 8|;89 	 kd|98|;8"/>
<parameter key="column_separator" value="\s+"/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
</operator>
<operator activated="true" class="split" compatibility="9.9.002" expanded="true" height="82" name="Split" width="90" x="246" y="136">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="attributes" value=""/>
<parameter key="use_except_expression" value="false"/>
<parameter key="value_type" value="nominal"/>
<parameter key="use_value_type_exception" value="false"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="use_block_type_exception" value="false"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="invert_selection" value="false"/>
<parameter key="include_special_attributes" value="false"/>
<parameter key="split_pattern" value="\|"/>
<parameter key="split_mode" value="ordered_split"/>
</operator>
<operator activated="true" class="de_pivot" compatibility="9.9.002" expanded="true" height="82" name="De-Pivot" width="90" x="447" y="34">
<list key="attribute_name">
<parameter key="ch_1" value="ch_1.*"/>
<parameter key="ch_2" value="ch_2.*"/>
<parameter key="va_1" value="va_1.*"/>
<parameter key="va_2" value="va_2.*"/>
</list>
<parameter key="index_attribute" value="index"/>
<parameter key="create_nominal_index" value="false"/>
<parameter key="keep_missings" value="true"/>
</operator>
<connect from_op="Create ExampleSet" from_port="output" to_op="Split" to_port="example set input"/>
<connect from_op="Split" from_port="example set output" to_op="De-Pivot" to_port="example set input"/>
<connect from_op="Split" from_port="original" to_port="result 3"/>
<connect from_op="De-Pivot" from_port="example set output" to_port="result 1"/>
<connect from_op="De-Pivot" from_port="original" to_port="result 2"/>
<portSpacing port="sink_result 3" spacing="0"/>
<portSpacing port="sink_result 4" spacing="0"/>
</process>
</operator>
</process>
