<?xml version="1.0" encoding="UTF-8"?><process version="9.9.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.9.002" expanded="true" name="Process">
<parameter key="notification_email" value="yhuang@rapidminer.com"/>
<parameter key="process_duration_for_mail" value="1"/>
<parameter key="encoding" value="UTF-8"/>
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.9.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="34">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="no ch_1 ch_2 va_1 va_2 123 sh|;ty|;hi hi|;sh 8|;cir|;89 98|;8 126 sd|;tf	 hi|;sh|df 8|;89 	 kd|98|;8"/>
<parameter key="column_separator" value="\s+"/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<operator activated="true" class="split" compatibility="9.9.002" expanded="true" height="82" name="Split" width="90" x="246" y="136">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="split_pattern" value="\|"/>
<parameter key="split_mode" value="ordered_split"/>
<operator activated="true" class="de_pivot" compatibility="9.9.002" expanded="true" height="82" name="De-Pivot" width="90" x="447" y="34">
<list key="attribute_name">
<parameter key="ch_1" value="ch_1.*"/>
<parameter key="ch_2" value="ch_2.*"/>
<parameter key="va_1" value="va_1.*"/>
<parameter key="va_2" value="va_2.*"/>
</list>
<parameter key="index_attribute" value="index"/>
<parameter key="create_nominal_index" value="false"/>
<parameter key="keep_missings" value="true"/>
<connect from_op="Create ExampleSet" from_port="output" to_op="Split" to_port="example set input"/>
<connect from_op="Split" from_port="example set output" to_op="De-Pivot" to_port="example set input"/>
<connect from_op="Split" from_port="original" to_port="result 3"/>
<connect from_op="De-Pivot" from_port="example set output" to_port="result 1"/>
<connect from_op="De-Pivot" from_port="original" to_port="result 2"/>
</process>
