1 - 4 of
41
Hi - To enable https on RTS API(routing from 8090 to AI Hub 8443), I have got a link to check on reverse proxy using apache/nginx(https://docs.rapidminer.com/latest/legacy/configure/security/reverse-proxy.html). Also I received above link which talk about certificates. Do you know If I need to follow both of the steps above discussed or just doing the certificates part would be fine. I am trying to check on the path where I can achieve routing from http to https with minimal to no install of new software to be done as apache/nginx might require some additional steps from our enterprise.
There is a docs article about adding certificates
https://docs.rapidminer.com/latest/scoring-agent/deploy-rts/webui/#certificates
Greetings,
Jonas
