🎉Community Raffle - Win $25
Join and Win
comparing two datasets and calculating multiple values
User: "RaphiHD"
New Altair Community Member
Updated by Jocelyn
Hello there,
I'm doing some kind of dictionary-based emotion-analysis in which I want to compare a set of text messages against a dictionary. The text message dataset consist of the three attributes "date", "sender" and the "message" itself. The dictionary marks the corresponding emotion for each word with a boolean marker like the following:
wordemo1emo2emo3
w1101
w2100
w3010
w4011
After processing the text messages and the lexicon (cases, stopwords, tokenize, stem), I end up with a word vector for the text message dataset that displays the count of each word for every message:
datesenderw1w2w3w4
1.1.alex0010
2.1.max1001
3.1.lisa1010
3.1.alex2100
My goal is to create a table in which a score for each of the emotions is calculated for every message. To do so, the corresponding words for every emotion need to be counted and the sum should be displayed like the following:
datesenderemo1emo2emo3
1.1.alex010
2.1.max112
3.1.lisa111
3.1.alex302
Now my question is, how can I compare the two datasets and calculate the individual scores? I was trying to use the "Intersect" operator for merging the two datasets together, as can be seen in my process, but another obstacle is that I'll have multiple tokens in one message, so it will only display messages that contain a single token.
An example for the lexicon and the messages is attached. I'd be thankful for your help.
<?xml version="1.0" encoding="UTF-8"?><process version="9.9.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.9.000" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="9.9.000" expanded="true" height="68" name="Retrieve Testdaten_Emolexikon" width="90" x="45" y="340">
        <parameter key="repository_entry" value="../data/Diplomarbeit/Testdaten_Emolexikon"/>
      </operator>
      <operator activated="true" class="select_attributes" compatibility="9.9.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="179" y="340">
        <parameter key="attribute_filter_type" value="subset"/>
        <parameter key="attribute" value=""/>
        <parameter key="attributes" value="english|sadness|joy"/>
        <parameter key="use_except_expression" value="false"/>
        <parameter key="value_type" value="attribute_value"/>
        <parameter key="use_value_type_exception" value="false"/>
        <parameter key="except_value_type" value="time"/>
        <parameter key="block_type" value="attribute_block"/>
        <parameter key="use_block_type_exception" value="false"/>
        <parameter key="except_block_type" value="value_matrix_row_start"/>
        <parameter key="invert_selection" value="false"/>
        <parameter key="include_special_attributes" value="false"/>
      </operator>
      <operator activated="true" class="text:process_document_from_data" compatibility="9.3.001" expanded="true" height="82" name="Process Documents from Data (2)" width="90" x="313" y="340">
        <parameter key="create_word_vector" value="false"/>
        <parameter key="vector_creation" value="Term Occurrences"/>
        <parameter key="add_meta_information" value="true"/>
        <parameter key="keep_text" value="true"/>
        <parameter key="prune_method" value="none"/>
        <parameter key="prune_below_percent" value="3.0"/>
        <parameter key="prune_above_percent" value="30.0"/>
        <parameter key="prune_below_absolute" value="2"/>
        <parameter key="prune_above_absolute" value="4"/>
        <parameter key="prune_below_rank" value="0.05"/>
        <parameter key="prune_above_rank" value="0.95"/>
        <parameter key="datamanagement" value="double_sparse_array"/>
        <parameter key="data_management" value="auto"/>
        <parameter key="select_attributes_and_weights" value="false"/>
        <list key="specify_weights"/>
          <operator activated="false" class="text:transform_cases" compatibility="9.3.001" expanded="true" height="68" name="Transform Cases (2)" width="90" x="112" y="34">
            <parameter key="transform_to" value="lower case"/>
          </operator>
          <operator activated="false" class="text:filter_stopwords_english" compatibility="9.3.001" expanded="true" height="68" name="Filter Stopwords (English) (2)" width="90" x="246" y="34"/>
          <operator activated="true" class="text:stem_porter" compatibility="9.3.001" expanded="true" height="68" name="Stem (Porter) (2)" width="90" x="380" y="34"/>
          <connect from_port="document" to_op="Stem (Porter) (2)" to_port="document"/>
          <connect from_op="Stem (Porter) (2)" from_port="document" to_port="document 1"/>
          <portSpacing port="source_document" spacing="0"/>
          <portSpacing port="sink_document 1" spacing="0"/>
          <portSpacing port="sink_document 2" spacing="0"/>
        </process>
      </operator>
      <operator activated="true" class="set_role" compatibility="9.9.000" expanded="true" height="82" name="Set Role" width="90" x="447" y="340">
        <parameter key="attribute_name" value="text"/>
        <parameter key="target_role" value="id"/>
        <list key="set_additional_roles"/>
      </operator>
      <operator activated="true" class="retrieve" compatibility="9.9.000" expanded="true" height="68" name="Retrieve messages" width="90" x="45" y="34">
        <parameter key="repository_entry" value="../data/Diplomarbeit/messages"/>
      </operator>
      <operator activated="true" class="select_attributes" compatibility="9.9.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
        <parameter key="attributes" value="date|sender|message"/>
      </operator>
      <operator activated="true" class="text:process_document_from_data" compatibility="9.3.001" expanded="true" height="82" name="Process Documents from Data" width="90" x="313" y="34">
        <parameter key="create_word_vector" value="true"/>
          <operator activated="true" class="text:transform_cases" compatibility="9.3.001" expanded="true" height="68" name="Transform Cases" width="90" x="112" y="34">
          </operator>
          <operator activated="true" class="text:tokenize" compatibility="9.3.001" expanded="true" height="68" name="Tokenize (2)" width="90" x="246" y="34">
            <parameter key="mode" value="non letters"/>
            <parameter key="characters" value=".:"/>
            <parameter key="language" value="English"/>
            <parameter key="max_token_length" value="3"/>
          </operator>
          <operator activated="true" class="text:filter_stopwords_english" compatibility="9.3.001" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="380" y="34"/>
          <operator activated="true" class="text:filter_by_length" compatibility="9.3.001" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="514" y="34">
            <parameter key="min_chars" value="3"/>
            <parameter key="max_chars" value="25"/>
          </operator>
          <operator activated="true" class="text:stem_porter" compatibility="9.3.001" expanded="true" height="68" name="Stem (Porter)" width="90" x="648" y="34"/>
          <connect from_port="document" to_op="Transform Cases" to_port="document"/>
          <connect from_op="Transform Cases" from_port="document" to_op="Tokenize (2)" to_port="document"/>
          <connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
          <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
          <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
          <connect from_op="Stem (Porter)" from_port="document" to_port="document 1"/>
        </process>
      </operator>
      <operator activated="true" class="set_role" compatibility="9.9.000" expanded="true" height="82" name="Set Role (2)" width="90" x="447" y="34">
      </operator>
      <operator activated="true" class="intersect" compatibility="9.9.000" expanded="true" height="82" name="Intersect" width="90" x="648" y="34"/>
      <connect from_op="Retrieve Testdaten_Emolexikon" from_port="output" to_op="Select Attributes (2)" to_port="example set input"/>
      <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Process Documents from Data (2)" to_port="example set"/>
      <connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Set Role" to_port="example set input"/>
      <connect from_op="Set Role" from_port="example set output" to_op="Intersect" to_port="second"/>
      <connect from_op="Retrieve messages" from_port="output" to_op="Select Attributes" to_port="example set input"/>
      <connect from_op="Select Attributes" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
      <connect from_op="Process Documents from Data" from_port="example set" to_op="Set Role (2)" to_port="example set input"/>
      <connect from_op="Set Role (2)" from_port="example set output" to_op="Intersect" to_port="example set input"/>
      <connect from_op="Intersect" from_port="example set output" to_port="result 1"/>
      <connect from_op="Intersect" from_port="original" to_port="result 2"/>
      <portSpacing port="sink_result 3" spacing="0"/>
      <description align="center" color="orange" colored="true" height="425" resized="true" width="157" x="10" y="10">Input</description>
      <description align="center" color="red" colored="true" height="427" resized="true" width="394" x="170" y="10">Processing</description>
      <description align="center" color="yellow" colored="true" height="430" resized="true" width="476" x="567" y="10">Analysis</description>
    </process>
  </operator>
</process>
