Altair RISE
Nominate Yourself Now!
How can i create ranges for a variable?
User: "Tdragi13"
New Altair Community Member
Updated by Jocelyn
So, using the Aggregate function I need to make a chart presenting the standard deviation of "Mo_Income" separated by gender and by international limit. And also I will have to create ranges for the variable first.
Im doing well with the first part but i don´t know how to create the ranges for the variable
1 - 3 of 31
    User: "Caperez"
    Hi @Tdragi13
    Can you share a sample of your data?
    in order to discretize your dataset you can use, for example the Discretize by User Specification operator, (go to Cleansing->Binning).
    Another option is creating  a new Attribute using logical functions and value intervals.
    Best
    User: "Tdragi13"
    OP
    Hi @ceaperez! here is a screenshot of a sample of my data!
    User: "Caperez"
    Hi @Tdragi13
    this is a simple example appliying the Discretize by User Specification operator.
    next time, please share the process or dataset.
    Best.
    <?xml version="1.0" encoding="UTF-8"?><process version="9.9.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.9.000" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="generate_data" compatibility="9.9.000" expanded="true" height="68" name="Generate Data" width="90" x="112" y="187">
            <parameter key="target_function" value="random"/>
            <parameter key="number_examples" value="30"/>
            <parameter key="number_of_attributes" value="1"/>
            <parameter key="attributes_lower_bound" value="380.0"/>
            <parameter key="attributes_upper_bound" value="650.0"/>
            <parameter key="gaussian_standard_deviation" value="10.0"/>
            <parameter key="largest_radius" value="10.0"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
            <parameter key="datamanagement" value="double_array"/>
            <parameter key="data_management" value="auto"/>
          </operator>
          <operator activated="true" class="discretize_by_user_specification" compatibility="9.9.000" expanded="true" height="103" name="Discretize" width="90" x="380" y="187">
            <parameter key="return_preprocessing_model" value="false"/>
            <parameter key="create_view" value="true"/>
            <parameter key="attribute_filter_type" value="single"/>
            <parameter key="attribute" value="att1"/>
            <parameter key="attributes" value=""/>
            <parameter key="use_except_expression" value="false"/>
            <parameter key="value_type" value="numeric"/>
            <parameter key="use_value_type_exception" value="false"/>
            <parameter key="except_value_type" value="real"/>
            <parameter key="block_type" value="value_series"/>
            <parameter key="use_block_type_exception" value="false"/>
            <parameter key="except_block_type" value="value_series_end"/>
            <parameter key="invert_selection" value="false"/>
            <parameter key="include_special_attributes" value="false"/>
            <list key="classes">
              <parameter key="1" value="430.0"/>
              <parameter key="2" value="490.0"/>
              <parameter key="3" value="540.0"/>
              <parameter key="4" value="650.0"/>
            </list>
          </operator>
          <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/>
          <connect from_op="Discretize" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
