Community & Support
Learn
Marketplace
Discussions
Categories
Discussions
General
Platform
Academic
Partner
Regional
User Groups
Documentation
Events
Altair Exchange
Share or Download Projects
Resources
News & Instructions
Programs
YouTube
Employee Resources
This tab can be seen by employees only. Please do not share these resources externally.
Groups
Join a User Group
Support
Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
analyzing data that is labeled with positive ( +1) and negative (-1),
charly
Dear Guys ,,
how are you? many thanks for your help ,, i really need your advice ,, firstly , I have analyse my data that is labeled with positive ( +1) and negative (-1), " what i do is I put every single comment in a text file and create 2 folders the first is for positive comments and the other is for negative comments ,then I analyze them i use KNN and SVM "
Now i have build a lexicon as a CSV file , every word and its weight , i need to enhance my results by using the lexicon weights , so how you can help me to use weights of the new lexicon with the weights that I have from the SVM model ??
what i have to do ?
many thanks in advance , i appreciated your help
AI Studio
Accepted answers
All comments
YYH
Hi
@charly
Do you want to add the weights from SVM as new features? If so, you can join the weight table with the vectorized text. The weights from SVM is usually used to explain the feature importance, select features for dimension reduction, and normalize input data by feature weights. Take a look at the tutorial process of "select by weights" and "scale by weights" operator.
Cheers,
YY
charly
hello yyhuang ,,,
i think to use the update model to update my results and to use the words in lexicon that is matches in the data file that i use before ,, what is ur advice ??
i will attach my work ,, but the update model tells me there is an error some where ,, i need some help pleease !!!
SVM with lexicon.rmp
charly
hello guys ,, i'm confused , i have get to academy and community ,, i didin't find really what i need !!!
any help or any informations ??
YYH
Hi
@charly
, thanks for sharing the process for SVM. Do you have input data to run it? I saw you skipped the training step inside cross validation. You directly retrieve a pretrained model and use it for testing. Why? Do you still want to use the feature weights from SVM?
charly
hello
@yyhuang
,thank you , i have an input data that is my whole data , then i have used cross validation for retrieve data that is use the weights from the SVM , but i want to update weights and enhance them by using the weights from the lexicon ( the CSV file ) , where i can but my new wights ??!! thats my question
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
