Twitter Academic Research Dev Account
renanpwagner
renanpwagner New Altair Community Member
edited November 2024 in Community Q&A
Hi,
I was wondering if anyone is using the Twitter Academic Research Dev account to stream tweets using the Twitter connector here on RapidMiner. I was planning to collect historical tweets using the Academic Research Dev account but I am unsure if that is possible or not
Welcome!
Answers
  • Caperez
    Caperez Altair Community Member
    edited March 2021
    I worked with it once.
    in order to have access to the desired data I wrote an explanation of data type and amount in my academic account request.
    I obtained the complete access without problem.
    My recomendation is to ask to twitter team about the dataset access. If you have access to the dataset you can use Twitter operator from Rapidminer.
    regards
  • renanpwagner
    thanks for the answer. I got access already, but the twitter connector operator here on RapidMiner does not seem to have the parameters that academic dev accounts are able to access (ie historical tweets) [or at least I haven't figured out how to do it]. Let's say that I wanted to collect all tweets from August 2018 from a specific user, what would be the configuration on the connector?
  • Caperez
    Hi @renanpwagner
    Hi,
    An easy option to to that is using the Get Twitter User Statuses operator and then with the FIlter Expamples operator filter by Created-At Atribute.
    Regards
Welcome!
Welcome!
