🎉Community Raffle - Win $25
Join and Win
creating word cloud
User: "wclaster"
New Altair Community Member
Updated by Jocelyn
Hello. I am using the operators: Process Documents from Files, and inside that there are Tokenize, Filter stopwords, Stem, Transform cases (please see xml attached). The output exa and wor are both connected to res ports. When checking the results panel there are two tabs. WordList and ExampleSet (see attached). I would think that I would want to create a word cloud from the output of the WordList (in particular from either Total Occurances or Document Occurances). However in the WordList display there is no button for Visualizations in this tab (there is for the ExampleSet tab). Can someone guide me from here to create the word cloud? Thank you!
1 - 5 of 51
    User: "atimm"
    Accepted Answer
    Updated by atimm
    Hello @wclaster,
    it seems that you have using the free license currently. You should be able to get a free full license for university usage and then follow https://docs.rapidminer.com/latest/studio/installation/license-install.html to use it.
    With that license the Visualizations tab will show up on the left in your screenshot.
    Best,
    Andreas
    User: "wclaster"
    OP
    Thank you. It seems you are correct. I am not using the educational license. Also, it seems that my educational license has expired. It says
    RapidMiner Studio 7.2+Educationalxxxxx@xxxx Expired Fri, Feb 19th
     2021
    How can I renew it?
    Thanks again!
    User: "Caperez"
    Accepted Answer
    Hi @wclaster,
    please  loggin in to your account in Rapidminer.com, go to My Account, Educational program and apply for a new accademic license.
    regards
    User: "wclaster"
    OP
    Thanks. I was able to change the license and will try the word cloud.
    User: "Caperez"
    Great, good luck!
