🎉Community Raffle - Win $25
Join and Win
I need an operator like the inverse of Filter Stopwords (Dictionary) operator
User: "Fatmah"
New Altair Community Member
Updated by Jocelyn
Hi
Thanks for reading my post
I work on my master thesis and I find same my problem here in this link
http://community.rapidminer.com/t5/RapidMiner-Studio/SOLVED-Filter-text-from-a-list-of-word/td-p/21459
He solve the problem by changing the code for filterstopword(dictionary)
I read the document "How to extend rapidminer"
I prepare the envirmonet by downloding Java and Eclipse Java Neon
I know now how to create my own operator but I don't know how to copy existing operator code and modify it ?
Thank you again
1 - 6 of 61
    User: "Thomas_Ott"
    Have you checked out the Filter Stopwords by Dictionary operator? There you can provide a custom txt file for stopwords.
    User: "Fatmah"
    OP
    Hi Thomas
    Thanks for replay
    Yes, I checked it many times
    The operator will filter out the document from the words in text file
    I want the filter to filter the document from all words exepet the words inside the text file
    the opposite what I need ..
    User: "Thomas_Ott"
    Would Filter by Content help? It has an inverse condition. What about Filter by POS tags? That also has an inverse condition.
    User: "Fatmah"
    OP
    I try Filter by content but it is insufficient for my situation because the text file have tens of words
    Filter by content will be good for very small number of expression
    In Filter by POS tag ? I can't determine the words I want !
    Thank you again for your help and yes plz if you have any suggestion tell me or if you know how I can reach the code ?
    User: "hmhsing"
    I changed the dictionary txt file into Excel and then use Filter Tokens Using ExampleSet (need check invert filter), it works. See the attached file.
    User: "kayman"
    In theory you could use the process documents from data operator and use your reversed stoplist (or whitelist) as a wordlist, this would allow only the words in your list as acceptable. There is no real out of the box operator to create your own wordlist but this one goes more in detail :
    https://community.rapidminer.com/discussion/51131/creating-a-comparing-white-list-of-words-to-a-wordlist-from-a-data-mined-webpage
