RapidMiner Studio AutoModel
tonyboy9
Altair Community Member
What am I doing wrong that the Results Overview shows 'error' across all three models?
0
Best Answers
Hi @tonyboy9,
One way to debug what you observe is to open the process associated to one of your model.
Then run this process in RapidMiner Studio to determine which operator is raising an error...
In the same time, can you share you dataset in order we can reproduce your error and try to understand what is going on ?
Regards,
Lionel
0
Answers
Okay, Ceaperez, thank for responding. I chose the Sample data set Deals. I ran the data set.
I ran TurboPrep.
I ran AutoModel.
The results were normal, no error results.
The errors data set contains many more attributes than Deals.
Have you any suggestions? Thanks.
Tony
0 -
Hi @tonyboy9,
Regards,
Lionel
0
