RapidMiner Studio AutoModel
tonyboy9
What am I doing wrong that the Results Overview shows 'error' across all three models?
Caperez
Hi
@tonyboy9
I'm trying to reproduce the error.
Normally you need al least 100 rows to run automodel.
Can you share your log info to view the errors?
regards
lionelderkrikor
Hi
@tonyboy9
One way to debug what you observe is to open the process associated to one of your model.
Then run this process in RapidMiner Studio to determine which operator is raising an error...
In the same time, can you share you dataset in order we can reproduce your error and try to understand what is going on ?
Lionel
Caperez
Hi
@tonyboy9
are you having the same problem when run automodel with any dataset?
can you try to run the automodel with an example dataset from Rapidminer and share the resutls?
regards
tonyboy9
Okay, Ceaperez, thank for responding. I chose the Sample data set Deals. I ran the data set.
I ran TurboPrep.
I ran AutoModel.
The results were normal, no error results.
The errors data set contains many more attributes than Deals.
Have you any suggestions? Thanks.
Tony
Caperez
Hi
@tonyboy9
regards
lionelderkrikor
Hi
@tonyboy9
Lionel
