question about one of the tutorials
In the first tutorial, called "Getting Started". In section 4/5, after building the simplest of decision trees on the Titanic Training data set, after performing the process, in the tutorial it says
Actually, I don't see exactly what they are referring to. Just from looking at that tree (see attachment), what do they mean by
what the survivors (or victims) have in common?
I don't exactly know how the are reading the tree to say that. Apparently it is obvious since they did not explain it but I don't follow. THANK YOU.
"Great job! Your process should now be complete and deliver a decision
tree model, which explains to you what most of the survivors and most of
the victims had in common."
