🎉Community Raffle - Win $25
Join and Win
Preparing the extension template, issue with gradle
anaRodriguesUser: "anaRodrigues"
New Altair Community Member
Updated by Jocelyn
Can't initialize the project:
./gradlew --no-daemon initializeExtensionProject
 I get this error:
To honour the JVM settings for this build a single-use Daemon process will be forked. See https://docs.gradle.org/6.8/userguide/gradle_daemon.html#sec:disabling_the_daemon.
Daemon will be stopped at the end of the build
FAILURE: Build failed with an exception.
* What went wrong:
com.google.common.util.concurrent.ExecutionError: java.lang.NoClassDefFoundError: org/gradle/api/internal/java/JavaLibrary
Also, on eclipse I get this error:
Could not run phased build action using connection to Gradle distribution 'https://services.gradle.org/distributions/gradle-6.8-bin.zip'.
org/gradle/api/internal/java/JavaLibrary rapidminer-extension-template-master line 0 Gradle Error Marker
I don't know what to do here, could someone help please?
1 - 9 of 91
    gmeierUser: "gmeier"
    Hi @anaRodrigues,
    are you using the extension template from https://github.com/rapidminer/rapidminer-extension-template? I am a bit puzzled that this is using gradle 6.8 for you; when running 'gradlew -version' this leads to a 4.6 version for me. Just executing 'gradlew --no-daemon initializeExtensionProject' in the folder which contains the README.md should work. The error you quoted could be caused by a wrong gradle version, so try to ensure that you are using a 4.x version. We are working on making the extensions compatible with gradle 6 but that template has not been adjusted yet.
    Hi @gmeier,
    You are right, I had changed the gradle version to match the one I have installed. I did everything from the beginning without changing anything and still got an error. I will try downgrading the gradle version on eclipse.
    Description Resource Path Location Type
    Could not run build action using connection to Gradle distribution 'https://services.gradle.org/distributions/gradle-4.6-bin.zip'.
    Unable to start the daemon process.
    This problem might be caused by incorrect configuration of the daemon.
    For example, an unrecognized jvm option is used.
    Please refer to the user guide chapter on the daemon at https://docs.gradle.org/4.6/userguide/gradle_daemon.html
    Please read the following process output to find out more:
    * What went wrong:
    Could not create service of type DaemonContext using DaemonServices.createDaemonContext().
    * Try:
    Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
    * Get more help at https://help.gradle.org rapidminer-extension-template-master line 0 Gradle Error Marker
    Thank you,
    Ana
    you can also try without the --no-daemon, that should work, too. Maybe that helps already.
    If it does not work with eclipse, just go to the folder and run it in the command line:
    (also works with --no-daemon but then there is no popup and instead you need to enter Y)
    Hi @gmeier,
    Still not working (from command line):
    * What went wrong:
    Could not determine java version from '15.0.2'.
    * Try:
    Thanks,
    Ana
    we are making progress :) Now you need a java 8 version for gradle.
    You can check with 'gradlew -version', there the JVM should be 1.8.
    You can either point your JAVA_HOME environment variable to a jdk 8 or try to use org.gradle.java.home=/path_to_jdk_directory in the gradle.properties.
    Hi @gmeier,
    This is where my JAVA_HOME is pointing:
    Also, my java version:
    PS C:\> javac -version
    javac 15.0.2
    The gradlew -version command is not recognized.
    PS C:\> gradlew -version
    gradlew : The term 'gradlew' is not recognized as the name of a cmdlet, function, script file, or operable program.
    Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
    At line:1 char:1
    + gradlew -version
        + CategoryInfo          : ObjectNotFound: (gradlew:String) [], CommandNotFoundException
        + FullyQualifiedErrorId : CommandNotFoundException
    I have the GRADLE_HOME environment variable set, so I don't know why the command is not working.
    I have also downgraded my gradle version to this 4.6
    However, if I ask for the gradle version:
    PS C:\> gradle -version
    * What went wrong:
    * Try:
    I get the same error as before.
    Sorry for the trouble and thank you,
    Ana
    Hi @anaRodrigues,
    yes, that means you have Java 15, but you need 8. You can for example download it from here and then point your JAVA_HOME to it.
    For the 'gradlew -version' command, you need to go to your extension-template folder and execute it there.
    OP
    Accepted Answer
    Hi @gmeier
    I believe now both my java and gradle versions are correct:
    When I try to initialize, I get this error:
    PS C:\Users\ASUS\Documents\Mestrado BBC\tese\rapidminer-extension-template-master> ./gradlew initializeExtensionProject Starting a Gradle Daemon (subsequent builds will be faster)
    * What went wrong:
    A problem occurred configuring root project 'rapidminer-extension-template-master'.
    > Could not resolve all dependencies for configuration ':provided'.
       > Could not resolve com.rapidminer.studio:rapidminer-studio-settings:9.8.0.
         Required by:
             project : > com.rapidminer.studio:rapidminer-studio-core:9.8.0
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-settings/9.8.0/rapidminer-studio-settings-9.8.0.pom
                > Could not find com.rapidminer:rapidminer-dependencies:9.8.0.
                  Searched in the following locations:
                      https://jcenter.bintray.com/com/rapidminer/rapidminer-dependencies/9.8.0/rapidminer-dependencies-9.8.0.pom
                      https://jcenter.bintray.com/com/rapidminer/rapidminer-dependencies/9.8.0/rapidminer-dependencies-9.8.0.jar
                      https://maven.rapidminer.com/content/groups/public/com/rapidminer/rapidminer-dependencies/9.8.0/rapidminer-dependencies-9.8.0.pom
                      https://maven.rapidminer.com/content/groups/public/com/rapidminer/rapidminer-dependencies/9.8.0/rapidminer-dependencies-9.8.0.jar
       > Could not resolve com.rapidminer.studio:rapidminer-studio-interfaces:9.8.0.
         Required by:
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-interfaces/9.8.0/rapidminer-studio-interfaces-9.8.0.pom
       > Could not resolve com.rapidminer.studio:rapidminer-studio-filesystem:9.8.0.
         Required by:
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-filesystem/9.8.0/rapidminer-studio-filesystem-9.8.0.pom
       > Could not resolve com.rapidminer.studio:rapidminer-studio-license:9.8.0.
         Required by:
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-license/9.8.0/rapidminer-studio-license-9.8.0.pom
       > Could not resolve com.rapidminer.studio:rapidminer-studio-logging:9.8.0.
         Required by:
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-logging/9.8.0/rapidminer-studio-logging-9.8.0.pom
       > Could not resolve com.rapidminer.studio:rapidminer-studio-i18n:9.8.0.
         Required by:
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-i18n/9.8.0/rapidminer-studio-i18n-9.8.0.pom
       > Could not resolve com.rapidminer.studio:rapidminer-studio-security:9.8.0.
         Required by:
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-security/9.8.0/rapidminer-studio-security-9.8.0.pom
       > Could not resolve com.rapidminer.studio:rapidminer-studio-tools:9.8.0.
         Required by:
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-tools/9.8.0/rapidminer-studio-tools-9.8.0.pom
       > Could not resolve com.rapidminer.studio:rapidminer-studio-encryption:9.8.0.
         Required by:
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-encryption/9.8.0/rapidminer-studio-encryption-9.8.0.pom
       > Could not resolve com.rapidminer.studio:rapidminer-studio-globalsearch:9.8.0.
         Required by:
             > Could not parse POM https://maven.rapidminer.com/content/groups/public/com/rapidminer/studio/rapidminer-studio-globalsearch/9.8.0/rapidminer-studio-globalsearch-9.8.0.pom
    * Try:
    Deprecated Gradle features were used in this build, making it incompatible with Gradle 5.0.
    See https://docs.gradle.org/4.6/userguide/command_line_interface.html#sec:command_line_warnings
    BUILD FAILED in 18s
    Ana
    User: "jczogalla"
    Accepted Answer
    Hi @anaRodrigues
    It seems there was a problem with our dependency management and this was fixed in our maven on Friday. You might have to clear your maven cache for the RapidMiner Studio artifact, but now it should work. :)
    Cheers
    Jan
