My custom operator has no input or output ports
Here's my process.
<div><?xml version="1.0" encoding="UTF-8"?><process version="9.8.001"></div><div> <context></div><div> <input/></div><div> <output/></div><div> <macros/></div><div> </context></div><div> <operator activated="true" class="process" compatibility="9.8.001" expanded="true" name="Process"></div><div> <parameter key="logverbosity" value="init"/></div><div> <parameter key="random_seed" value="2001"/></div><div> <parameter key="send_mail" value="never"/></div><div> <parameter key="notification_email" value=""/></div><div> <parameter key="process_duration_for_mail" value="30"/></div><div> <parameter key="encoding" value="SYSTEM"/></div><div> <process expanded="true"></div><div> <operator activated="false" class="read_csv" compatibility="9.8.001" expanded="true" height="68" name="Read CSV" width="90" x="45" y="289"></div><div> <parameter key="csv_file" value="C:/Users/ASUS/Documents/Mestrado BBC/tese/4. Feature Extraction/Gland_data/gland_trainSet_stable.csv"/></div><div> <parameter key="column_separators" value=","/></div><div> <parameter key="trim_lines" value="false"/></div><div> <parameter key="use_quotes" value="true"/></div><div> <parameter key="quotes_character" value="""/></div><div> <parameter key="escape_character" value="\"/></div><div> <parameter key="skip_comments" value="false"/></div><div> <parameter key="comment_characters" value="#"/></div><div> <parameter key="starting_row" value="1"/></div><div> <parameter key="parse_numbers" value="true"/></div><div> <parameter key="decimal_character" value="."/></div><div> <parameter key="grouped_digits" value="false"/></div><div> <parameter key="grouping_character" value=","/></div><div> <parameter key="infinity_representation" value=""/></div><div> <parameter key="date_format" value=""/></div><div> <parameter key="first_row_as_names" value="true"/></div><div> <list key="annotations"/></div><div> <parameter key="time_zone" value="SYSTEM"/></div><div> <parameter key="locale" value="English (United States)"/></div><div> <parameter key="encoding" value="SYSTEM"/></div><div> <parameter key="read_all_values_as_polynominal" value="false"/></div><div> <list key="data_set_meta_data_information"/></div><div> <parameter key="read_not_matching_values_as_missings" value="true"/></div><div> <parameter key="datamanagement" value="double_array"/></div><div> <parameter key="data_management" value="auto"/></div><div> </operator></div><div> <operator activated="false" class="filter_examples" compatibility="9.8.001" expanded="true" height="103" name="Remove missing data" width="90" x="179" y="289"></div><div> <parameter key="parameter_expression" value=""/></div><div> <parameter key="condition_class" value="no_missing_attributes"/></div><div> <parameter key="invert_filter" value="false"/></div><div> <list key="filters_list"/></div><div> <parameter key="filters_logic_and" value="true"/></div><div> <parameter key="filters_check_metadata" value="true"/></div><div> </operator></div><div> <operator activated="false" class="set_role" compatibility="9.8.001" expanded="true" height="82" name="Set Role (2)" width="90" x="313" y="289"></div><div> <parameter key="attribute_name" value="ID"/></div><div> <parameter key="target_role" value="id"/></div><div> <list key="set_additional_roles"></div><div> <parameter key="ID" value="id"/></div><div> <parameter key="Target" value="label"/></div><div> </list></div><div> </operator></div><div> <operator activated="false" class="naive_bayes" compatibility="9.8.001" expanded="true" height="82" name="Naive Bayes (4)" width="90" x="447" y="289"></div><div> <parameter key="laplace_correction" value="true"/></div><div> </operator></div><div> <operator activated="false" class="read_csv" compatibility="9.8.001" expanded="true" height="68" name="Read CSV (2)" width="90" x="313" y="391"></div><div> <parameter key="csv_file" value="C:/Users/ASUS/Documents/Mestrado BBC/tese/4. Feature Extraction/Gland_data/gland_trainSet_stable.csv"/></div><div> <parameter key="column_separators" value=","/></div><div> <parameter key="trim_lines" value="false"/></div><div> <parameter key="use_quotes" value="true"/></div><div> <parameter key="quotes_character" value="""/></div><div> <parameter key="escape_character" value="\"/></div><div> <parameter key="skip_comments" value="false"/></div><div> <parameter key="comment_characters" value="#"/></div><div> <parameter key="starting_row" value="1"/></div><div> <parameter key="parse_numbers" value="true"/></div><div> <parameter key="decimal_character" value="."/></div><div> <parameter key="grouped_digits" value="false"/></div><div> <parameter key="grouping_character" value=","/></div><div> <parameter key="infinity_representation" value=""/></div><div> <parameter key="date_format" value=""/></div><div> <parameter key="first_row_as_names" value="true"/></div><div> <list key="annotations"/></div><div> <parameter key="time_zone" value="SYSTEM"/></div><div> <parameter key="locale" value="English (United States)"/></div><div> <parameter key="encoding" value="SYSTEM"/></div><div> <parameter key="read_all_values_as_polynominal" value="false"/></div><div> <list key="data_set_meta_data_information"/></div><div> <parameter key="read_not_matching_values_as_missings" value="true"/></div><div> <parameter key="datamanagement" value="double_array"/></div><div> <parameter key="data_management" value="auto"/></div><div> </operator></div><div> <operator activated="false" class="set_role" compatibility="9.8.001" expanded="true" height="82" name="Set Role (5)" width="90" x="447" y="391"></div><div> <parameter key="attribute_name" value="ID"/></div><div> <parameter key="target_role" value="id"/></div><div> <list key="set_additional_roles"></div><div> <parameter key="Target" value="label"/></div><div> </list></div><div> </operator></div><div> <operator activated="false" class="apply_model" compatibility="9.8.001" expanded="true" height="82" name="Apply Model (4)" width="90" x="581" y="289"></div><div> <list key="application_parameters"/></div><div> <parameter key="create_view" value="false"/></div><div> </operator></div><div> <operator activated="true" class="performance_binominal_classification" compatibility="9.8.001" expanded="true" height="82" name="Performance" width="90" x="45" y="34"></div><div> <parameter key="manually_set_positive_class" value="false"/></div><div> <parameter key="main_criterion" value="first"/></div><div> <parameter key="accuracy" value="true"/></div><div> <parameter key="classification_error" value="false"/></div><div> <parameter key="kappa" value="true"/></div><div> <parameter key="AUC (optimistic)" value="false"/></div><div> <parameter key="AUC" value="true"/></div><div> <parameter key="AUC (pessimistic)" value="false"/></div><div> <parameter key="precision" value="true"/></div><div> <parameter key="recall" value="true"/></div><div> <parameter key="lift" value="false"/></div><div> <parameter key="fallout" value="false"/></div><div> <parameter key="f_measure" value="false"/></div><div> <parameter key="false_positive" value="false"/></div><div> <parameter key="false_negative" value="false"/></div><div> <parameter key="true_positive" value="false"/></div><div> <parameter key="true_negative" value="false"/></div><div> <parameter key="sensitivity" value="false"/></div><div> <parameter key="specificity" value="false"/></div><div> <parameter key="youden" value="false"/></div><div> <parameter key="positive_predictive_value" value="false"/></div><div> <parameter key="negative_predictive_value" value="false"/></div><div> <parameter key="psep" value="false"/></div><div> <parameter key="skip_undefined_labels" value="true"/></div><div> <parameter key="use_example_weights" value="true"/></div><div> </operator></div><div> <operator activated="true" class="operator_toolbox:performance_auprc" compatibility="2.9.000" expanded="true" height="82" name="Performance (AUPRC)" width="90" x="179" y="34"></div><div> <parameter key="main_criterion" value="first"/></div><div> <parameter key="accuracy" value="true"/></div><div> <parameter key="AUC" value="false"/></div><div> <parameter key="AUPRC" value="false"/></div><div> <parameter key="skip_undefined_labels" value="true"/></div><div> <parameter key="use_example_weights" value="true"/></div><div> </operator></div><div> <operator activated="true" class="multiply" compatibility="9.8.001" expanded="true" height="103" name="Multiply" width="90" x="313" y="136"/></div><div> <operator activated="true" class="performance_to_data" compatibility="9.8.001" expanded="true" height="82" name="Performance to Data" width="90" x="447" y="34"/></div><div> <operator activated="true" class="python_scripting:execute_python" compatibility="9.8.000" expanded="true" height="103" name="Execute Python" width="90" x="581" y="34"></div><div> <parameter key="script" value="import pandas as pd import numpy as np # rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none), # or the number of input ports plus one if "use macros" parameter is set # if you want to use macros, use this instead and check "use macros" parameter: #def rm_main(data,macros): def rm_main(data): #print(float(data.loc[data["Criterion"]=="precision","Value"])) p = float(data.loc[data["Criterion"]=="precision","Value"]) r = float(data.loc[data["Criterion"]=="recall","Value"]) f = (1 + %{beta}**2)*p*r / (%{beta}**2 * p + r) data = data.set_index("Criterion") data = data.transpose() data["Fbeta-score"]=f data = data.dropna() #print(data.columns) #df = pd.DataFrame({"Criterion":"Fbeta-score", "Value":f}, columns=data.columns) #df = pd.DataFrame([["Fbeta-score", f, np.nan, np.nan]], columns=data.columns) #data.append(df, ignore_index=True) return data"/></div><div> <parameter key="notebook_cell_tag_filter" value=""/></div><div> <parameter key="use_default_python" value="true"/></div><div> <parameter key="package_manager" value="conda (anaconda)"/></div><div> <parameter key="use_macros" value="false"/></div><div> </operator></div><div> <operator activated="true" class="extract_performance" compatibility="9.8.001" expanded="true" height="82" name="Performance (2)" width="90" x="715" y="34"></div><div> <parameter key="performance_type" value="data_value"/></div><div> <parameter key="statistics" value="average"/></div><div> <parameter key="attribute_name" value="%{metric_to_optimize}"/></div><div> <parameter key="example_index" value="1"/></div><div> <parameter key="optimization_direction" value="maximize"/></div><div> </operator></div><div> <operator activated="true" class="multiply" compatibility="9.8.001" expanded="true" height="103" name="Multiply (2)" width="90" x="849" y="34"/></div><div> <operator activated="true" class="collect" compatibility="9.8.001" expanded="true" height="103" name="Collect" width="90" x="983" y="136"></div><div> <parameter key="unfold" value="false"/></div><div> </operator></div><div> <operator activated="true" class="set_macro" compatibility="9.8.001" expanded="true" height="68" name="beta" width="90" x="179" y="136"></div><div> <parameter key="macro" value="beta"/></div><div> <parameter key="value" value="2"/></div><div> </operator></div><div> <operator activated="true" class="process_defined_operators:category_parameter_macro" compatibility="0.9.007" expanded="true" height="68" name="Metric to optimize" width="90" x="45" y="136"></div><div> <enumeration key="possible_values"></div><div> <parameter key="value" value="AUPRC"/></div><div> <parameter key="value" value="Fbeta-score"/></div><div> <parameter key="value" value="AUC"/></div><div> <parameter key="value" value="precision"/></div><div> <parameter key="value" value="recall"/></div><div> <parameter key="value" value="Kappa"/></div><div> </enumeration></div><div> <parameter key="macro" value="metric_to_optimize"/></div><div> <parameter key="value" value="AUPRC"/></div><div> </operator></div><div> <connect from_port="input 1" to_op="Performance" to_port="labelled data"/></div><div> <connect from_op="Read CSV" from_port="output" to_op="Remove missing data" to_port="example set input"/></div><div> <connect from_op="Remove missing data" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/></div><div> <connect from_op="Set Role (2)" from_port="example set output" to_op="Naive Bayes (4)" to_port="training set"/></div><div> <connect from_op="Naive Bayes (4)" from_port="model" to_op="Apply Model (4)" to_port="model"/></div><div> <connect from_op="Read CSV (2)" from_port="output" to_op="Set Role (5)" to_port="example set input"/></div><div> <connect from_op="Set Role (5)" from_port="example set output" to_op="Apply Model (4)" to_port="unlabelled data"/></div><div> <connect from_op="Performance" from_port="performance" to_op="Performance (AUPRC)" to_port="performance"/></div><div> <connect from_op="Performance" from_port="example set" to_op="Performance (AUPRC)" to_port="labelled data"/></div><div> <connect from_op="Performance (AUPRC)" from_port="performance" to_op="Multiply" to_port="input"/></div><div> <connect from_op="Multiply" from_port="output 1" to_op="Performance to Data" to_port="performance vector"/></div><div> <connect from_op="Multiply" from_port="output 2" to_op="Collect" to_port="input 2"/></div><div> <connect from_op="Performance to Data" from_port="example set" to_op="Execute Python" to_port="input 1"/></div><div> <connect from_op="Execute Python" from_port="output 1" to_op="Performance (2)" to_port="example set"/></div><div> <connect from_op="Performance (2)" from_port="performance" to_op="Multiply (2)" to_port="input"/></div><div> <connect from_op="Multiply (2)" from_port="output 1" to_port="result 1"/></div><div> <connect from_op="Multiply (2)" from_port="output 2" to_op="Collect" to_port="input 1"/></div><div> <connect from_op="Collect" from_port="collection" to_port="result 2"/></div><div> <portSpacing port="source_input 1" spacing="0"/></div><div> <portSpacing port="source_input 2" spacing="0"/></div><div> <portSpacing port="sink_result 1" spacing="0"/></div><div> <portSpacing port="sink_result 2" spacing="0"/></div><div> <portSpacing port="sink_result 3" spacing="0"/></div><div> </process></div><div> </operator></div><div></process></div>
