Will changing license remove key files?
I have a completely new license (different company and login) for RM Studio. Will changing to the new license remove important files and directories such as extensions, repositories, marketplace licenses, etc? If so, how can I retain these? Is there a single 'license' file that I can change and avoid the hassle?
Separately, what about RapidMiner Academy? Can I 'transfer' courses to my new account?
1 - 2 of
21
1 - 1 of
11
@ecdbert all the extension and local repositories stay the same.
Only if you had payed extension from the previous job those may no longer work with your new license.
The one thing you would lose is the access rights to the AI-Hub because those belong to the other company you used to work for and they own those process and data.
We will need to check what could be done regarding your Academy performance please reach out to support team or your CSM and ask him to get the most accurate answer on this subject.
