🎉Community Raffle - Win $25
Join and Win
Splitting based on the values in an attribute
User: "sectyn"
New Altair Community Member
Updated by Jocelyn
I have a set of rows with missing values in one attribute. I would like to split the data based on the attribute with missing values in such a way that the sets will have rows upto the row which has some value in that attribute.
For example if the example set is:
Att1   Att2    Att3
a      test1
b      test2
c      test3    val3
d      test4
e      test5
f      test6
g      test7    val7
h      test8
i        test9
So after the split, I want 2 sets:
a     test1
b     test2
c      test3    val3
d     test4
e     test5
f      test6
g     test7    val7
Tried this in Loop Values, but not sure how to do the split.
1 - 2 of 21
    User: "BalazsBaranyRM"
    Accepted Answer
    Hi @jennyclub,
    this kind of row-spanning processing is quite hard in RapidMiner.
    I would try something like this:
    1. Get the the index of non-empty Att3 values. E. g. Generate ID, Filter Examples.
    2. Loop the filtered index values (they need to be converted into nominal) and filter the other rows based ID <= current index.
    3. Extract the current Att3 value with Extract Macro and write it into the filtered table with Generate Attributes.
    I hope this gives you an idea.
    Regards,
    Balázs
    User: "sectyn"
    OP
    Thank you, Balázs. This really helped.
