Depivot json with different number of attributes
How does one depivot a json file that has two different categories, with some shared and some unshared attributes that leads to different attribute counts?
Does one have to split the file before de-pivoting or is there a better way of selecting the attributed for de-pivoting?
I have attached the process as well as the json file.
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="9.3.001" expanded="true" height="68" name="Read Document" width="90" x="112" y="34"> <parameter key="file" value="/Users/robinmeisel/Dropbox/Ornico/Instagram/json/radioawards.json"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="text:json_to_data" compatibility="9.3.001" expanded="true" height="82" name="JSON To Data" width="90" x="246" y="34"> <parameter key="ignore_arrays" value="false"/> <parameter key="limit_attributes" value="false"/> <parameter key="skip_invalid_documents" value="false"/> <parameter key="guess_data_types" value="true"/> <parameter key="keep_missing_attributes" value="false"/> <parameter key="missing_values_aliases" value=", null, NaN, missing"/> </operator> <operator activated="true" class="de_pivot" compatibility="9.7.002" expanded="true" height="82" name="De-Pivot (5)" width="90" x="380" y="34"> <list key="attribute_name"> <parameter key="comment" value=".*edge_media_to_comment.*"/> <parameter key="text" value=".*edge_media_to_caption.*"/> <parameter key="liked" value=".*edge_liked_by.*"/> <parameter key="name" value=".*node.owner.username.*"/> <parameter key="url" value=".*node.display_url.*"/> </list> <parameter key="index_attribute" value="id"/> <parameter key="create_nominal_index" value="false"/> <parameter key="keep_missings" value="false"/> </operator> <connect from_op="Read Document" from_port="output" to_op="JSON To Data" to_port="documents 1"/> <connect from_op="JSON To Data" from_port="example set" to_op="De-Pivot (5)" to_port="example set input"/> <connect from_op="De-Pivot (5)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
