🎉Community Raffle - Win $25
Join and Win
Hello everyone,I want prediction with aply model and linear regression but ı want prediction all at
User: "Rümeysa"
New Altair Community Member
Updated by Jocelyn
Hello everyone,I want prediction with aply model and linear regression but ı want  prediction all attrübutes.How can use set role
1 - 2 of 21
    User: "BalazsBaranyRM"
    Accepted Answer
    Hi,
    check out Loop Attributes. This will go through the list of attributes you select, and inside the loop you can use Set Role to mark the current attribute as the label. Put your modeling and prediction process into the loop. Use Store inside the loop with a variable name (e. g. including the loop_attribute macro) to save the result of each iteration.
    Regards,
    Balázs
    User: "Rümeysa"
    OP
    Thank you @BalazsBarany .I am new I will try it
    Regards,
    Rümeysa
