Community & Support
Learn
Marketplace
Discussions
Categories
Discussions
General
Platform
Academic
Partner
Regional
User Groups
Documentation
Events
Altair Exchange
Share or Download Projects
Resources
News & Instructions
Programs
YouTube
Employee Resources
This tab can be seen by employees only. Please do not share these resources externally.
Groups
Join a User Group
Support
Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
Filter tokens (by Pos Tags) without generating n-grams
HeikoeWin786
Dear all,
I am performing process documents from data using tokenize, transform cases, filter tokens by length, filter stopwords (English), stem(Porter) and filter token (by pos tags).
It is taking so long to run like almost 6 hours.
I am not sure if I am doing things incorrectly.
May I know if it is ok to use Filter tokens (by Pos Tags) without generating n-grams? or, we must generate the n-grams first?
thanks
AI Studio
Accepted answers
jacobcybulski
I think this is happening because Porter (alike Snowball) stemmer is algorithmic and does not create parts of speech tags. For the POS filter to work you may need to use a dictionary-based stemmer, such as WordNet. Try to skip the POS filter and see if this makes any difference.
All comments
jacobcybulski
jacobcybulski
Also as a test, downsample your documents to just a few to see if it goes through these at all.
jacobcybulski
n-grams make tokens out of a pair or 3 tokens which commonly go together, such as not-bad - they will have no impact on pos-tag filtering. However, if you use n-grams it will slow processing considerably.
HeikoeWin786
@jacobcybulski
Thanks a lot. Based on your input, I did some research and I am very much clear now.
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
