🎉Community Raffle - Win $25
Join and Win
can i show my decision tree model from forward selection operator?
User: "michelleprizcillya"
New Altair Community Member
Updated by Jocelyn
hi, i'm working on my thesis and it need to show the decision tree model. in forward selection operator it only have three output, it contains example set, attribute weights and perfomance. is there any techniques that i can try to show the model output? thank you
1 - 3 of 31
    User: "Telcontar120"
    You just need to connect the "mod" port output at the end and it will show the model both graphically and in rule form.
    OP
    Sorry but i can not connect the port because in forward selection operator there’s no way to connect the “mod” to the “per” port ouput
    User: "lionelderkrikor"
    Accepted Answer
    Hi @ michelleprizcillya,
    Yo can use the Remember/recall operators to extract the mod output from the Forward Selection operator.
    See the process in attached file to understand.
    Regards,
    Lionel
