Access violation error when running nonlinear forward analysis by the command line interface
Hello,
I'm trying to run a nonlinear forward analysis by the command line interface. I can perform the exact same analysis in the GUI, using the same files, but when I use the command lines I get an access violation error. I've granted MDS_driver_main.exe every possible read and write permission.
Why is this not working?
