Java could not be launched
Hi, I downloaded Rapidminer of latest version, also checked updated for Java. When I launch rapidminer studio there is pop up with error code 1
I tried do delete .Rapidminer folder but it didnt solve anything.
Here is log file:
окт 17, 2020 10:01:47 PM com.rapidminer.tools.LaunchListener getOtherInstance
WARNING: Found lock file but no other instance running. Assuming unclean shutdown of previous launch.
окт 17, 2020 10:01:47 PM com.rapidminer.gui.safemode.SafeMode launchStarts
INFO: Found left-behind lock file from last startup at C:\Users\den-b\.RapidMiner\safeMode.lock.
Oct 17, 2020 10:01:47 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Oct 17, 2020 10:01:49 PM com.rapidminer.gui.RapidMinerGUI run
INFO: Launching RapidMiner 9.8.000, platform WIN64
Oct 17, 2020 10:01:49 PM com.rapidminer.tools.PlatformUtilities logInfo
INFO: rapidminer.home is 'C:\Program Files\RapidMiner\RapidMiner Studio'.
Oct 17, 2020 10:01:50 PM com.rapidminer.tools.ProxySettings$ProxyVoleLogger log
WARNING: File reading error.
WARNING: Loading script failed from:
with error java.io.IOException:
(Синтаксическая ошибка в имени файла, имени папки или метке тома)
Oct 17, 2020 10:01:50 PM com.rapidminer.core.license.ProductConstraintManager initialize
INFO: Initializing license manager.
INFO: Using default license location.
INFO: Registering default product.
Oct 17, 2020 10:01:50 PM com.rapidminer.repository.FileRepositoryProvider load
WARNING: Unknown tag: filesystemRepository
Oct 17, 2020 10:01:50 PM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category repository registered.
Oct 17, 2020 10:01:50 PM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: Cloud Connectivity
INFO: Register plugin: Data Editor
INFO: Register plugin: H2O
INFO: Register plugin: Model Deployment Management
INFO: Register plugin: Model Simulator
INFO: Register plugin: Operator Recommender
INFO: Register plugin: Process Scheduling
INFO: Register plugin: Advanced File Connectors
INFO: Register plugin: Blending
INFO: Register plugin: Browser
INFO: Register plugin: Concurrency
INFO: Register plugin: CTA
INFO: Register plugin: HTML5 Charts
INFO: Register plugin: JDBC Connectors
INFO: Register plugin: Legacy Result Access
INFO: Register plugin: Productivity
INFO: Register plugin: Professional
INFO: Register plugin: Remote Repository
INFO: Register plugin: Utility
INFO: Register plugin: Social Media
INFO: Register plugin: Time Series
Oct 17, 2020 10:01:52 PM com.rapidminer.tools.config.ConfigurationManager register
INFO: Registered configurator Twitter Connection.
Oct 17, 2020 10:01:52 PM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
INFO: Async: Init browser setup.
INFO: Registered configurator Salesforce Connection.
INFO: Registered configurator Amazon S3 Connection.
INFO: Registered configurator Azure Blob Storage Connection.
INFO: Registered configurator Azure Data Lake Storage Gen1 Connection.
INFO: Registered configurator gui.configurable.cloud.azure.gen2.name.
INFO: Registered configurator Google Cloud Storage Connection.
INFO: Registered configurator Dropbox Connection.
Oct 17, 2020 10:01:53 PM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
WARNING: Missing database driver class name for Ingres
Oct 17, 2020 10:01:53 PM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
INFO: Async: Basic browser setup test starting.
Oct 17, 2020 10:01:54 PM com.rapidminer.extension.browser.PluginInitBrowser lambda$initPlugin$2
INFO: Async: Created basic browser instance.
INFO: Async: Loaded basic browser test content. Executing functionality check.
INFO: Async: Basic browser setup test successful.
Oct 17, 2020 10:01:54 PM com.rapidminer.repository.RepositoryManager registerExtensionSamples
INFO: Registered 'Time Series' as sample folder.
Oct 17, 2020 10:01:54 PM com.rapidminer.tools.plugin.Plugin initAll
INFO: Extension Blending was loaded in 108ms.
INFO: Extension Process Scheduling was loaded in 113ms.
INFO: Extension Data Editor was loaded in 119ms.
INFO: Extension Operator Recommender was loaded in 124ms.
INFO: Extension Productivity was loaded in 130ms.
INFO: Extension Legacy Result Access was loaded in 130ms.
INFO: Extension Concurrency was loaded in 136ms.
INFO: Extension Social Media was loaded in 138ms.
INFO: Extension CTA was loaded in 143ms.
INFO: Extension Utility was loaded in 149ms.
INFO: Extension Time Series was loaded in 169ms.
INFO: Extension Model Deployment Management was loaded in 169ms.
INFO: Extension Advanced File Connectors was loaded in 169ms.
INFO: Extension Professional was loaded in 177ms.
INFO: Extension Remote Repository was loaded in 180ms.
INFO: Extension Browser was loaded in 191ms.
INFO: Extension Model Simulator was loaded in 200ms.
INFO: Extension HTML5 Charts was loaded in 214ms.
INFO: Extension H2O was loaded in 313ms.
INFO: Extension Cloud Connectivity was loaded in 553ms.
INFO: Extension JDBC Connectors was loaded in 567ms.
Oct 17, 2020 10:01:54 PM com.rapidminer.search.GlobalSearchRegistry registerSearchCategory
INFO: Global Search category operator registered.
1 - 3 of
31
