Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
Date values conversion
RyanRezel
Hi,
I am fairly new to RM and my first task has a column with inconsistent date values, it is entered as for example 0055 for the year whereas it should be 1955, I have tried a few options but have failed can anyone provide me with some assistance, please.
Thanks
Ryan
AI Studio
Accepted answers
MartinLiebig
Hi
@RyanRezel
attached is an easy way how to do it. I am not 100% sure about your date format, so you may adapt this a bit more.
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.7.002" expanded="true" name="Process">
<parameter key="logverbosity" value="init"/>
<parameter key="random_seed" value="2001"/>
<parameter key="send_mail" value="never"/>
<parameter key="notification_email" value=""/>
<parameter key="process_duration_for_mail" value="30"/>
<parameter key="encoding" value="SYSTEM"/>
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.7.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="34">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="date 0019 0050 1920 1992"/>
<parameter key="column_separator" value=","/>
<parameter key="parse_all_as_nominal" value="true"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
</operator>
<operator activated="true" class="replace" compatibility="9.7.002" expanded="true" height="82" name="Replace" width="90" x="246" y="34">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="date"/>
<parameter key="attributes" value=""/>
<parameter key="use_except_expression" value="false"/>
<parameter key="value_type" value="nominal"/>
<parameter key="use_value_type_exception" value="false"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="use_block_type_exception" value="false"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="invert_selection" value="false"/>
<parameter key="include_special_attributes" value="false"/>
<parameter key="replace_what" value="00(\d\d)"/>
<parameter key="replace_by" value="19$1"/>
</operator>
<operator activated="false" class="nominal_to_date" compatibility="9.7.002" expanded="true" height="82" name="Nominal to Date" width="90" x="447" y="34">
<parameter key="attribute_name" value="date"/>
<parameter key="date_type" value="date"/>
<parameter key="date_format" value="yyyy"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="keep_old_attribute" value="false"/>
<description align="center" color="transparent" colored="false" width="126">if you want to you can convert this now</description>
</operator>
<connect from_op="Create ExampleSet" from_port="output" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
All comments
MartinLiebig
Hi,
that's nasty, who came up with this notation? What would be 0019? 1919 or 2019?
In any case, i suspect you need to read it in as a Polynominal value and then parse the string. For example with Generate attributes.
Best,
Martin
RyanRezel
Hi
mschmitz
I assumed it was 1919 for example since in the statistics tab it shows that the latest date is May 7, 1992.
Is hope such an assumption alright.
Can you elaborate on how I can parse it, please?
thank you
Ryan
MartinLiebig
Hi
@RyanRezel
Best,
Martin
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
RyanRezel
Thank you very much Martin.
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
