Missing Test Date Column in Forecast Validation
Hi
I was following the Elaborate Your Time Series Analysis video: https://www.youtube.com/watch?time_continue=2182&v=Hvdh8ItfiGA&feature=emb_logo
It clearly shows a date column when you're doing a performance (regression) analysis using ARIMA. Pls see YouTube "Elaborate Your Time Series" video image.
I set up my process the same as the video but don't have this test date to refer to?
Pls see images:
and yet I set the attribute as Date as in the video instructions?
So could someone please tell me how do I get a date reference?
Also is there a way to swap the order of the close column and the forecast column so that the forecast column comes first before the actual close?
Cheers,
Pls see images:
Cheers,
