Reconfigure Connections to Databases on the new AI Hub 9.7
Biersepp
Biersepp New Altair Community Member
edited November 2024 in Community Q&A
Hello,
I recently upgraded RM Server to AI hub on 9.7. This implementation was done in Docker on a Windows Server 2019 environment.
I just realized that the current connections on the Server instance are not working anymore. In Studio everything has been tested successfully.
On AI Hub I get the following message:
The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "java.security.cert.CertificateException: Certificates do not conform to algorithm constraints". ClientConnectionId:78adaf2a-004a-40d8-b39e-bd04c119f578
We don't have SSL enabled on the AI Hub. This hasen't been an issue since the latest upgrade. I guess KeyCloak might have something to do with it!?
Thanks for your help. We depend on this for a couple of WebApps we have deployed.
Welcome!
Best Answers
  • Biersepp
    Answer ✓
    @aschaferdiek
    Hi thank you for your answer. This helped a lot.
    On a side note, I also had to additionally change the driver to Microsoft SQL Server to jdbc:jdts. But without the URL changes it would not have worked.
    Thanks again!
Answers
  • sgenzer
    sgenzer
    Altair Employee
  • Biersepp
    Answer ✓
    @aschaferdiek
    Thanks again!
Welcome!
Welcome!
