How can I combine the result of SVN with a different classification method?
I need to create a prediciton model.
The file contains 5 columns:
- choice (label - polynominal)
- column_a (polynominal)
- column_b (real values)
- column_c (real values)
- column_d (real values)
I tested several combination of MODELS and I got the best results using BAGGING of SVN LibSVN (without using the ploynominl feature because SVN cannot use it)
Even if the accuracy seems good, I believe adding the missing feature should improve the results.
I tired to use VOTE and STACKING to combine results from SVN with another classifier model, but the problem is I cannot do it because the SVN does not include all the features.
1 - 3 of
31
All models in a Stacking ensemble must use the same label and the same attributes, so the best way to use a mix of models is to ensure they have the same pre-processing before hand, e.g. convert nominal attributes to numerical to please SVM or Logistic Regression, while Decision Tree will still perform well on transformed attributes.
@MorSha,
Hello
There are some great links for your question
you can take a look on them
https://academy.rapidminer.com/learn/article/ensemble-methods
https://docs.rapidminer.com/latest/studio/operators/modeling/predictive/ensembles/bagging.html
https://docs.rapidminer.com/latest/studio/operators/modeling/predictive/ensembles/stacking.html
Best
Sara
Hello
Best
Sara
