1 - 4 of
41
You can't do this directly in Auto Model, but you can run Auto Model and then simply open the generated GLM model process and adjust the parameter manually to exclude the intercept term (it is an expert parameter so you need to show them to see it).
@Telcontar120 Thanks for an answer! Could You please provide me screenshot? I cant find this option (
@dimitri here is the screenshot of the parameters for the GLM operator. I have circled the one where you can include or exclude the intercept. If you don't see that listed, I also circled something at the bottom that controls whether you can see the advanced parameters or not. If yours says "Show Advanced Parameters" then click on it and you should see all the ones in this image.
@dimitri
Hello
Also you can make GLM process in studio too. And in Auto Model the training and test part are 60% and 40% which you can do it easily.
Hello
