Altair RISE
Nominate Yourself Now!
how to remove two identical ID numbers within a single attribute?
User: "LeMarc"
New Altair Community Member
Updated by Jocelyn
Hi,
I would like to customize an expression which states:
If id attribute consist of two identicial ID numbers,  then delete one of the ID Nrs (doesnt matter which one),
 otherwise do nothing)
Can anybody help how to properly formulate ?
1 - 4 of 41
    Hi,
    can you give an example for this id?
    Best,
    Martin
    User: "LeMarc"
    OP
    The goal is to have an example set in which the attribute column "id" doesnt have the same id number twice.
    In this case, there are two examples/rows within the example set which exist twice (id number 23 & 46). Therefore I only want to keep only one example/row of each Id number which exist more than once
    User: "MartinLiebig"
    Altair Employee
    Accepted Answer
    Hi,
    The remove duplicates operator should do the trick.
    ~Martin
    User: "LeMarc"
    OP
    Thanks @mschmitz!
    Totally forgot about that option/operator.
