Execute SQL Operator - Calling Oracle Stored Procedure - Invalid SQL Statement
Trying to call an Oracle stored procedure using the Execute SQL operator and getting
Database error occurred: ORA-00900: invalid SQL statement.
The SP I'm trying to call is located within the schema that I've configured the connection for.
I can execute the SP successfully while connected via SQL Developer.
I've tried:
EXECUTE <SP_NAME>
EXECUTE <SCHEMA>.<SP_NAME>
EXEC <SP_NAME>
EXEC <SCHEMA>.<SP_NAME>
I was able to successfully run SELECT SYSDATE FROM DUAL using Execute SQL operator.
Thanks in advance.
1 - 2 of
21
Got it to work...mostly. I used a test stored procedure that had a date in the where clause and I was getting an error around that. Once I changed the query and removed the date reference (just to see if I can even get the StoredProc to run), I was successful in getting the stored procedure to be called. Thanks for the help!
1 - 1 of
11
Hi. I had the same issue and found a working solution on Stack Overflow (I can't post the link but search for answer # 47134774) - it seems JDBC does not recognize EXEC so instead wrap your SP within an anonymous PL/SQL block, i.e.:
BEGIN
<SP_NAME>
END;
BEGIN
<SP_NAME>
END;
BEGIN
<SP_NAME>
END;
