🎉Community Raffle - Win $25
Join and Win
classification model - problem with date column
User: "LeMarc"
New Altair Community Member
Updated by Jocelyn
Hi,
I  trained a model on an example set which includes a column date (DD.MM.YYYY) e.g. June 2020.
However the model cant be applied to another data set [with date e.g. July 2020] with exactly the same Features as in the data set to build the model. Theres always a an error which says : "mismatch of date".
Is it possible that the model cant be applied because of differen dates in the data set?
