Number of Attributes After Join Operation
Hi everyone,
After joining two datasets the Join Operator removes double attributes. However, I am seeing the removed attributes on the metadata popup window when I hover on the output node. I also see removed attributes in the list of Select Attributes Operator. Is this a bug or an intended result? I wonder If somebody could explain.
1 - 2 of
21
Hi,
maybe your definition of double attributes differs from RapidMiner's.
One instance of the duplicate attribute names is being kept by the Join operator. This is absolutely intentional. (In cases when the same attribute name has different contents in the example sets, you also want to keep the duplicate attributes.)
Also, the duplicate check is very thorough. Attribute names "data" and "Data" are already different enough to keep.
Regards,
Balázs
Regards,
Balázs
Hello
Take a look at these links please:
https://rapidminer.com/blog/tips-tricks-different-ways-to-join-data/#:~:text=Inner%20or%20Outer%2C%20Right%20or,match%20the%20records%20up%20with.
https://docs.rapidminer.com/latest/studio/operators/blending/table/joins/join.html
I hope this helps
Sara
