1 - 4 of
41
1 - 1 of
11
Nominal to Numerical operator will do that for you if you select "unique integers" in the parameters as the conversion method under "coding type." See the help description of that operator for more details.
Or you can use Nominal to Numerical to allow it to recode automatically.
In either case, be careful what you do with the resulting numerical data! It is not often the case that a strict numerical substitution like this is suitable for use in ML algorithms.
