Getting count of data dictionary occurences
Hey folks,
I have a process that is successfully looping through a collection of text files and getting the 10 most occurring words in each file. However I am now trying to add a data dictionary so that I am only doing this for words in the data dictionary. I am reading in a text file with a list of words for my data dictionary. However for the results I am getting just a count of 1 for each word when it appears. I know for example that without the data dictionary one word occurs 213 times in one text file however with the new process I am only seeing it counted once. I've tried a number of options but can't get it to count properly as before when using the data dictionary any pointers would be much appreciated.
Cheers,
Neil.
Cheers,
Neil.
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.7.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="concurrency:loop_files" compatibility="9.7.000" expanded="true" height="82" name="Loop Files" width="90" x="112" y="85"> <parameter key="directory" value="D:/OneDrive/College/Blanch/Year2/Project/docs/Complete/Mufc/arabic"/> <parameter key="filter_type" value="glob"/> <parameter key="recursive" value="false"/> <parameter key="enable_macros" value="true"/> <parameter key="macro_for_file_name" value="file_name"/> <parameter key="macro_for_file_type" value="file_type"/> <parameter key="macro_for_folder_name" value="folder_name"/> <parameter key="reuse_results" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="9.3.001" expanded="true" height="68" name="Read Document" width="90" x="45" y="136"> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="text:process_document_from_file" compatibility="9.3.001" expanded="true" height="82" name="Process Documents from Files" width="90" x="179" y="34"> <list key="text_directories"> <parameter key="list" value="C:/Users/Neil/Desktop/test"/> </list> <parameter key="file_pattern" value="*"/> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="create_word_vector" value="false"/> <parameter key="vector_creation" value="Term Occurrences"/> <parameter key="add_meta_information" value="false"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="9.3.001" expanded="true" height="68" name="Tokenize" width="90" x="179" y="85"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="9.3.001" expanded="true" height="68" name="Transform Cases" width="90" x="447" y="85"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="9.3.001" expanded="true" height="68" name="Filter Stopwords (English) (2)" width="90" x="715" y="85"/> <operator activated="true" class="text:filter_by_length" compatibility="9.3.001" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="983" y="85"> <parameter key="min_chars" value="4"/> <parameter key="max_chars" value="25"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English) (2)" to_port="document"/> <connect from_op="Filter Stopwords (English) (2)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:process_documents" compatibility="9.3.001" expanded="true" height="103" name="Process Documents (2)" width="90" x="246" y="187"> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="Term Occurrences"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="true"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="5.0"/> <parameter key="prune_above_rank" value="5.0"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="9.3.001" expanded="true" height="68" name="Tokenize (2)" width="90" x="45" y="85"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="9.3.001" expanded="true" height="68" name="Transform Cases (2)" width="90" x="179" y="85"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="9.3.001" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="313" y="85"/> <operator activated="true" class="text:filter_by_length" compatibility="9.3.001" expanded="true" height="68" name="Filter Tokens (by Length) (2)" width="90" x="514" y="85"> <parameter key="min_chars" value="4"/> <parameter key="max_chars" value="25"/> </operator> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length) (2)" to_port="document"/> <connect from_op="Filter Tokens (by Length) (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:wordlist_to_data" compatibility="9.3.001" expanded="true" height="82" name="WordList to Data" width="90" x="380" y="85"/> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="82" name="Generate Attributes" width="90" x="514" y="34"> <list key="function_descriptions"> <parameter key="filename" value="macro("file_name")"/> </list> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="sort" compatibility="9.7.000" expanded="true" height="82" name="Sort" width="90" x="447" y="238"> <parameter key="attribute_name" value="total"/> <parameter key="sorting_direction" value="decreasing"/> </operator> <operator activated="true" class="filter_example_range" compatibility="9.7.000" expanded="true" height="82" name="Filter Example Range" width="90" x="648" y="136"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="10"/> <parameter key="invert_filter" value="false"/> </operator> <connect from_port="file object" to_op="Read Document" to_port="file"/> <connect from_op="Read Document" from_port="output" to_op="Process Documents (2)" to_port="documents 1"/> <connect from_op="Process Documents from Files" from_port="word list" to_op="Process Documents (2)" to_port="word list"/> <connect from_op="Process Documents (2)" from_port="word list" to_op="WordList to Data" to_port="word list"/> <connect from_op="WordList to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_port="output 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Loop Files" to_port="input 1"/> <connect from_op="Loop Files" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
