Problem about Rapidminer Studio (Linux Version)
Hello, everyone
From today, I am using Rapidminer Studio for Linux
I installed it on CentOS 7 and java 1.8 is running on CentOS.
But when I start Rapidminer
there are several error messages and lots of warning
and if I try to edit text to edit boxes in Rapidminer UI
Rapidminer stopped and it says (on console)
"Could not find conda command in the current search path
Please add the folder, which contains the conda executable."
I captured and attached the error log messages
Please help me with this problem
Thank you and have a nice day, everyone
Hello, Marco. Thank you for you guide.
I will try as you said
But by the way, I have one more issue.
Now when I try to run Rapidminer(Linux), there's message saying
RAPIDMINER HOME is not set ...
and Rapidminer is running but the Graphic UI is not showing
my java on CentOS is Java 1.8
Could you please help me with this, why this is happening.??
Thank you..!
