Download Rapidminer 9.6.0 compiled
Referring to last post (which got no replies) I have come to the conclusion that the new rapidminer 9.7.0 update has broken the MLWizard extension. I'd like to revert to the 9.6.0 version, however the only way of doing so is going through github and manually building the application with java. Now this wouldnt be a problem if the dependencies it used werent over 3 years old and deprecated and hard to get by. I am therefore asking if any kind souls here have the .exe installing for rapidminer 9.6.0
1 - 5 of
51
@hbajpai could you by any chance send me the exe file? I for some reason cant actually login on the main page, I tried resetting the password. But everytime I click login nothing happens.
@hbajpai I sent you a PM, however there arent really that many details to disclose
Having tested the Rapidminer 9.6.0 version I can conclude it has not fixed the problems faced here: https://community.rapidminer.com/discussion/56922/mlwizard-stopped-working-filenotfoundexception#latest
It seems to be an issue surrounding Rapidminers online hosting services regarding the extension. Its not local and has been tried and tested on a different computer aswell
1 - 1 of
11
I just tried and in the my accounts, download section if you update the version to 9.6 at the end of page, you can directly download the compiled versions.
