Deformations in Hyperview
Hi !
I´m working in a crash simulation and I would like to know if it is possible to watch and measure the deformations after the impact in Hyperview. Because currently when I load the results in Hyperview it only shows the displacement but i need to know the deformations.
Is there any control card that help me to show the results (deformations) that I want to know??
Another question is:
How can I obtain the displacement tensor??
Could you help me to solve this request??
Regards,
Sebastian.
Deformations you can measure by checking the relative displacement of that part / elements.
Hi George,
How can I check in HyperView the relative displacement of the part / elements?
Could you explain to me how I can do that?
Regards,
Sebastian.
You can make use of the Measures panel in HV to check the relative displacement between nodes.See attached pdf and screenshot.
can you please tell how to know the scaling the mass if each component
Hi,
Add ANIM/SHEL/STRAIN or ANIM/BRIC/STRAIN.
Can you explain what do you mean by watch and measure deformations?
