🎉Community Raffle - Win $25
Join and Win
RADIOSS BLOCK - NON LINEAR ANALISYS PROBLEMS
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello together,
I have a question about a non linear analisys using RADIOSS explicit (Block110).
I'm studing a composite component, using a MATX25 card for the material. The component that I'm studying will have large deformation , and for these reason I'm using a non linear analisys type. It's a flexural analysis on a plate like a leaf spring.
I have some question about mesh type and dimension (using shell elements) :
1)How I can choose element dimension? There's a formula or specific rule? I ask this becouse I know that it depend by timestep, or better, the two issues are related..
2)I tried to use a SECOND ORDER element type, but the solver doesn't work; I use a first order element type...is a compatibility problem from the MATX25 or how I can use the second order elements?
While about the material formulation :
3)For these kind of analysis I used, in a MATX25 card the CRASURV formulation. I seen that there was a Plastic Strain from low values of load and when the load go to zero, the component don't return in the original position ; I think so that this kind of formulation is not the better for the problem studied. Can you suggest me something about it?
I've done some laboratory test and the model has a less stiffness compared to the realty ( three times..)
Thanks
Best Regards
1 - 11 of 111
    Altair Employee
    OP
    Hi,
    MATX25 is a OptiStruct Material card extension whereas MAT25 is for RADIOSS. please confirm this?
    1) in context of explicit analysis the timestep is dependent on characteristic length of the element and the material sound speed {(E/RHO)^0.5}. if you know the timestep for the simulation you can derive the characteristic length of the element based on this rule and the element size should not be less than the characteristic length.
    2) what kind of 2nd order elements are used in your model? do you have any contact interfaces?
    also, can you please let us know the version of HW you are using? use the link to find out the software update information http://www.altairuniversity.com/support-forum/?mingleforumaction=viewtopic&t=252
    3) I am not sure what is causing the problem, my suggestion would be check the unit consistency for material and properties in your model.
    Altair Employee
    OP
    [...] do you have any contact interfaces? [...]
    Can contact interfaces cause trouble? I am using Freeze contact to tie parts together but when I try to run a geometric non-linear analysis I get errors because of contact interfaces. Any clue? I have no problems with small displacement analysis, but only with large displacement analysis.
    Here one of around 800 identical errors:
    STARTER ERROR:
     ERROR ID :          556
     ** ERROR IN INTERFACE TYPE2
     DESCRIPTION :
        -- INTERFACE ID : 50
        -- INTERFACE TITLE : INTER_TYPE2_50
        MASTER NODE ID=97392 IS ALSO SLAVE NODE OF ANOTHER INTERFACE TYPE2
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Which version of Hyperworks you are using?Optistruct 14.0 nlstat for large displacement will work fine.
    Altair Employee
    OP
    Hi,
    Looks like the one of the nodes is in both master and slave. Try to clear that and try again.
    Altair Employee
    OP
    Yes, 14.0. So I should use non-linear static subcase instead of geometric nonlinear subcase? I will try.
    Btw, I have a modell with shell elements mainly. The documentation states that OptiStruct cannot perform large displacement analysis for shell elements. What should I do? Using Radioss? Is my OptiStruct modell fully compatible with Radioss?
    Altair Employee
    OP
    Hi,
    At several regions I have tied 3 parts together which means that one element (of component A) will be tied (freeze contact) to two other elements of components B and C.
    In OptiStruct 13.0/14.0 it works fine, but for geometric non-linear analysis the Radioss solver is used automatically. Maybe Radioss does not allow this definition, is that true?
    Altair Employee
    OP
    Not sure.
    Can you share the entire .out file and if possible the model file?
    Altair Employee
    OP
    The slave-master definition is definitely causing my problem with Radioss...I will have a look at it and try to fix it.
    Can you tell me where to activate the NLOUT entry? It does not seem to be available GUI...I cannot find it in HM14.0
    'The NLOUT entry can be used in the Subcase Information section to select the incremental result output parameters used for Nonlinear Static Analysis and Nonlinear Transient Analysis. '
    'The NLOUT bulk data entry defines incremental result output parameters for small displacement nonlinear analysis and large displacement analysis. '
    Altair Employee
    OP
    Hi Msc,
    You need to add NLOUT through Control Cards>> Bulk_UnSupported_Crads in a specified format as shown in the image.
    After adding the card, you need to refer the same in the loadcase by editing the loadcase/subcase>>Subcase_Unsupported cards.
    Next
    Altair Employee
    OP
    Hi Msc,
    Thank you, it works :-)
    Two more questions concerning non linear analysis:
    1) How can I control the output increments for NLGEOM analysis (Geom non-linear (impl static))? The NLOUT parameter seems to work only for NLSTAT anlysis.
    2) What is the difference between running a NLSTAT simulation and activating LGDISP and running a NLGEOM analysis?
    Is the stiffness matrix also updated during NLSTAT-LGDISP simulation? Are different solvers used? For a shell plate I get two different results as soon as I reach the buckling load...but the step sizes are different as well: With the same parameter NLPARM/NINC=20 which defines the first step size of 0.05 I get output 20 equidistant steps for NLSTAT-LGDISP, but only 13 steps for NLGEOM analysis. The time steps after reaching the buckling load are bigger for NLGEOM so it is hard to compare the curves as the output is not gained at the same time point.
    Altair Employee
    OP
    Hi,
    NLGEOM uses RADIOSS in the background so you get incemental results based on the frequency.
    NLSTAT without LGDISP will work for small displacement problems where as activating LGDISP will work for large displacement implicit problems.
