🎉Community Raffle - Win $25
Join and Win
Selecting Tokenized Attributes
User: "gn582"
New Altair Community Member
Updated by Jocelyn
Hey guys,
Using Rapidminer for the first time for one of my university subjects. I'm trying to make a decision tree that uses the least_square criterion as it has a numerical attribute as the label.
The data deals with Youtube attributes and I am trying to tokenize the tag column (which I can successfully do) and then select each tag individually using the "Select Attribute" operator so that I can input the data into the decision tree and have the number of likes column be the label for the decision tree.
The problem is when I process the tag data and tokenize it, I can only select the attribute "text" rather than each token individually. Is there a way around this or a way I can select each token to input into the data set?
Sorry if I worded it confusingly,
Thanks for the help!
1 - 3 of 31
    User: "lionelderkrikor"
    Accepted Answer
    Hi @gn582,
    If I good understand, you want select only the token attributes and exclude the "text" attribute ?
    In this case :
     - select attribute filter type = single
     - select your "text" attribute
    AND
     - check invert selection
    Regards,
    Lionel
    User: "gn582"
    OP
    Exactly what I wanted! Thanks heaps Lionel, was stuck on that problem for a while and couldn't figure out why it wouldn't work. Saved me so much time!
    Thanks again
    You're welcome @gn582,
    Good luck for your study !
    Regards,
    Lionel
