Altair RISE
Nominate Yourself Now!
Identifying the First value of an attribute
User: "swamysantoshkumar"
New Altair Community Member
Updated by Jocelyn
Could some one please let me know
1. How can we identify the first value of an attribute ?
2. How do we identify the first value of an attribute based on grouping ?
3. How do we create a new attribute with first value assigned based on grouping of other attributes ?
1 - 6 of 61
    User: "lionelderkrikor"
    Hi @swamysantoshkumar,
    To identify the first value of an attribute, you can use the Filter Example Range operator and set
    first example = 1
    last example = 1
    For you questions 2. and 3. I have difficulties to understand :
    Can you provide :
     -  an example of what you have and
     - an example of what you want to obtain
    Regards,
    Lionel
    OP
    Thanks for the response @Lionelderkrikor
    Below is the example in which I would need attributes 3 & 4 to be created from Attributes 1 & 2
    1. How do we identify the first value of an attribute and assign it as new attribute for all examples
    2. How do we identify the first value of an attribute specific to a group of examples
    3. How do we create the new attribute by assigning the first value identified in step 2
    I would like to generate Attribute 3 and 4 as depicted in the below table
    Ex:
    Attribute 1    Attribute 2   Attribute 3    Attribute 4
    A                     10                10                10
    A                      20               10                10
    A                      25               10                10
    A                      40               10                10
    B                      30               10                30
    B                      40               10                30
    C                      50               10                50
    C                      60               10                50
    @swamysantoshkumar,
    In attached file, a process to generate your att_3 based on att_1 and att_2.
    For your second request (generate att_4) I need a little time of reflexion ...
    Stay tuned !
    Regards,
    Lionel
    @swamysantoshkumar
    .....and here, in attached file, the final process (including generation of attribute 4) which use Group into Collection / Loop Collection operators
    Does this process answer to your need ?
    Regards,
    Lionel
    OP
    @lionelderkrikor
    Thank you so much ! Yes it really helps. This is what I was looking for.
    Thanks again..
    Santosh !
    You're welcome, @swamysantoshkumar.
    Good luck for your study !
    Regards,
    Lionel
