I need help with predicting an attribute
Hallo all,
I have a dataset that contains the yearly gas use 2010- 2018, temperature from 2010 - 2018, the provinces in the country that i want to analyze, and the speed of wind. What i want to do know is to predict what the usage of gas will be in the future. When i observe the data set it is clearly that the usage of gas is getting less by year and that there is correlation between temperature and gas usage. I tried to get an decision tree but it wont work for some reason.
Can someone help me with predicting the gas usage?
Thanks in advance
Thanks in advance
