🎉Community Raffle - Win $25
Join and Win
how to add quotes in all columns fields in rapidminer
User: "sgnarkhede2016"
New Altair Community Member
Updated by Jocelyn
e.g
In colunm values are
Sachin
Om
Shyam
I want
"Sachin"
"Om"
"Shyam"
1 - 3 of 31
    User: "lionelderkrikor"
    Accepted Answer
    Hi @sgnarkhede2016,
    You can use Generate Attributes operator for this task :
    In attached file, the process.
    Regards,
    Lionel
    User: "jwpfau"
    Altair Employee
    If you prefer regex you could also use Replace with replace what
    and replace by
    "$0"
    User: "Telcontar120"
    But why do you want the quotes inside RapidMiner, where they are not needed?  If it is merely to include in the file when exporting to another format, you have the option to put all nominal values inside quotes in operators such as "Write CSV".
