I installed the RM Server, but I could not start it. I tried the three ways provided in the document but all failed. The error informations are shown below.
Hi, I double-clicked the standalone.bat file within the installation directory bin/ folder. The result is shown below as the second picture in the question.
I read that this might pop up when your system is 64bit but your installed version of JRE is 32bit. Could you verify that you're using the correct JRE distribution?
It was resolved. I add an environment variable "JAVA_HOME" to the System Variable and it works. At the beginning, I add the JAVA_HOME variables to the User Variable. Thanks a lot for your help!!!
