1 - 7 of
71
hello @heydmagnus pls see my other post.
Hi @sgenzer, could you kindly link directly to your "other" post? I have the same problem and am a bit lost searching all your posts or similiar topics.
hi @PG2 hmm you were hoping for me to remember what I wrote on May 12?
Are you getting this error message?
Thanks for the quick response @sgenzer!
Yes, I am getting the same error message in a similiar scenario. Your post made me hope there was already a solution to this in another post you made, as your comment was also marked as the solution.
@PG2 your timing is good - this issue was just raised to Engineering recently. Can you please share with me via private message your rapidminer-studio.log file? It is in your .RapidMiner folder. I wish to see your error logs.
Thank you.
Thank you.
