Logistic Regression with polynominal attributes
Hi,
Novice here. My member type is a university professor but not in the data science field.
I am trying to run logistic regression using the data downloaded from here: https://www.kaggle.com/fayomi/advertising. As stated in the data description of the site, the goal is to predict people who are more likely to click the ad. I split the data into training and scoring data.
I want to get some help in how to handle the polynominal attributes in the data set. For example, there are so many Ad Topic Line and City values. When I ran the model, it ran but the results did not look right.
Also, the confidence percentage for ad click (yes, no) was either one or zero for all rows. I feel something might be wrong here.
Thanks for help...
Thanks for help...
1 - 3 of
31
hi @jykim so that was fun. Here's a quick solution.
Scott
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve advertising" width="90" x="45" y="85"> <parameter key="repository_entry" value="//NewLocalRepository/advertising"/> </operator> <operator activated="true" class="subprocess" compatibility="9.6.000" expanded="true" height="82" name="Subprocess" width="90" x="179" y="85"> <process expanded="true"> <operator activated="true" class="nominal_to_text" compatibility="9.6.000" expanded="true" height="82" name="Nominal to Text" width="90" x="45" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Ad Topic Line"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="9.3.001" expanded="true" height="82" name="Process Documents from Data" width="90" x="179" y="34"> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="true"/> <parameter key="prune_method" value="percentual"/> <parameter key="prune_below_percent" value="2.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <parameter key="select_attributes_and_weights" value="false"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="9.3.001" expanded="true" height="68" name="Tokenize" width="90" x="45" y="34"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="numerical_to_binominal" compatibility="9.6.000" expanded="true" height="82" name="Numerical to Binominal" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Clicked on Ad"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="min" value="0.0"/> <parameter key="max" value="0.0"/> </operator> <operator activated="true" class="set_role" compatibility="9.6.000" expanded="true" height="82" name="Set Role" width="90" x="447" y="34"> <parameter key="attribute_name" value="Clicked on Ad"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="map" compatibility="9.6.000" expanded="true" height="82" name="Map" width="90" x="581" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Country"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <list key="value_mappings"> <parameter key="United States of America" value="United States"/> <parameter key="Antarctica (the territory South of 60 deg S)" value="Antarctica"/> <parameter key="Bouvet Island (Bouvetoya)" value="Bouvet Island"/> <parameter key="British Indian Ocean Territory (Chagos Archipelago)" value="British Indian Ocean Territory"/> <parameter key="Brunei Darussalam" value="Brunei"/> <parameter key="Cote d'Ivoire" value="Ivory Coast (Côte d'Ivoire)"/> <parameter key="Falkland Islands (Malvinas)" value="Falkland Islands"/> <parameter key="Gambia" value="The Gambia"/> <parameter key="Holy See (Vatican City State)" value="Vatican City"/> <parameter key="Korea" value="South Korea"/> <parameter key="Kyrgyz Republic" value="Kyrgyzstan"/> <parameter key="Lao People's Democratic Republic" value="Laos"/> <parameter key="Libyan Arab Jamahiriya" value="Libya"/> <parameter key="Macao" value="Macau"/> <parameter key="Micronesia" value="Federated States of Micronesia"/> <parameter key="Netherlands Antilles" value="Caribbean Netherlands (Bonaire, Sint Eustatius and Saba)"/> <parameter key="Palestinian Territory" value="Palestine"/> <parameter key="Reunion" value="Réunion"/> <parameter key="Russian Federation" value="Russia"/> <parameter key="Saint Barthelemy" value="Saint Barthélemy"/> <parameter key="Saint Helena" value="Saint Helena, Ascension and Tristan da Cunha"/> <parameter key="Saint Martin" value="Saint Martin (French part)"/> <parameter key="Sao Tome and Principe" value="São Tomé and Principé"/> <parameter key="Slovakia (Slovak Republic)" value="Slovakia"/> <parameter key="Svalbard & Jan Mayen Islands" value="Svalbard and Jan Mayen"/> <parameter key="Syrian Arab Republic" value="Syria"/> <parameter key="Timor-Leste" value="East Timor"/> </list> <parameter key="consider_regular_expressions" value="false"/> <parameter key="add_default_mapping" value="false"/> </operator> <operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve World Countries" width="90" x="179" y="238"> <parameter key="repository_entry" value="//Community Samples/Community Data Sets/World Geography/World Countries"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes" width="90" x="313" y="238"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="Country Name|UN continental region"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="concurrency:join" compatibility="9.6.000" expanded="true" height="82" name="Join" width="90" x="782" y="136"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="left"/> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="Country" value="Country Name"/> </list> <parameter key="keep_both_join_attributes" value="false"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="9.6.000" expanded="true" height="103" name="Nominal to Numerical" width="90" x="916" y="136"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="UN continental region"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="coding_type" value="dummy coding"/> <parameter key="use_comparison_groups" value="false"/> <list key="comparison_groups"/> <parameter key="unexpected_value_handling" value="all 0 and warning"/> <parameter key="use_underscore_in_name" value="false"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical" width="90" x="1050" y="136"> <parameter key="attribute_name" value="Timestamp"/> <parameter key="time_unit" value="hour"/> <parameter key="millisecond_relative_to" value="epoch"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="month"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="true"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical (2)" width="90" x="1184" y="136"> <parameter key="attribute_name" value="Timestamp"/> <parameter key="time_unit" value="day"/> <parameter key="millisecond_relative_to" value="epoch"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="week"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="true"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical (3)" width="90" x="1318" y="136"> <parameter key="attribute_name" value="Timestamp"/> <parameter key="time_unit" value="week"/> <parameter key="millisecond_relative_to" value="epoch"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="month"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="true"/> </operator> <operator activated="true" class="date_to_numerical" compatibility="9.6.000" expanded="true" height="82" name="Date to Numerical (4)" width="90" x="1452" y="136"> <parameter key="attribute_name" value="Timestamp"/> <parameter key="time_unit" value="day"/> <parameter key="millisecond_relative_to" value="epoch"/> <parameter key="second_relative_to" value="minute"/> <parameter key="minute_relative_to" value="hour"/> <parameter key="hour_relative_to" value="day"/> <parameter key="day_relative_to" value="month"/> <parameter key="week_relative_to" value="year"/> <parameter key="month_relative_to" value="year"/> <parameter key="quarter_relative_to" value="year"/> <parameter key="half_year_relative_to" value="year"/> <parameter key="year_relative_to" value="era"/> <parameter key="keep_old_attribute" value="false"/> </operator> <operator activated="true" class="generate_attributes" compatibility="9.6.000" expanded="true" height="82" name="Generate Attributes" width="90" x="1653" y="136"> <list key="function_descriptions"/> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="1787" y="136"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="City|Country|Country Name|text"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_port="in 1" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Numerical to Binominal" to_port="example set input"/> <connect from_op="Numerical to Binominal" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Map" to_port="example set input"/> <connect from_op="Map" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Retrieve World Countries" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Date to Numerical" to_port="example set input"/> <connect from_op="Date to Numerical" from_port="example set output" to_op="Date to Numerical (2)" to_port="example set input"/> <connect from_op="Date to Numerical (2)" from_port="example set output" to_op="Date to Numerical (3)" to_port="example set input"/> <connect from_op="Date to Numerical (3)" from_port="example set output" to_op="Date to Numerical (4)" to_port="example set input"/> <connect from_op="Date to Numerical (4)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="concurrency:cross_validation" compatibility="9.6.000" expanded="true" height="145" name="Cross Validation" width="90" x="313" y="85"> <parameter key="split_on_batch_attribute" value="false"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_folds" value="10"/> <parameter key="sampling_type" value="automatic"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="h2o:logistic_regression" compatibility="9.3.001" expanded="true" height="124" name="Logistic Regression" width="90" x="112" y="34"> <parameter key="solver" value="AUTO"/> <parameter key="reproducible" value="false"/> <parameter key="maximum_number_of_threads" value="4"/> <parameter key="use_regularization" value="false"/> <parameter key="lambda_search" value="false"/> <parameter key="number_of_lambdas" value="0"/> <parameter key="lambda_min_ratio" value="0.0"/> <parameter key="early_stopping" value="true"/> <parameter key="stopping_rounds" value="3"/> <parameter key="stopping_tolerance" value="0.001"/> <parameter key="standardize" value="true"/> <parameter key="non-negative_coefficients" value="false"/> <parameter key="add_intercept" value="true"/> <parameter key="compute_p-values" value="true"/> <parameter key="remove_collinear_columns" value="true"/> <parameter key="missing_values_handling" value="MeanImputation"/> <parameter key="max_iterations" value="0"/> <parameter key="max_runtime_seconds" value="0"/> </operator> <connect from_port="training set" to_op="Logistic Regression" to_port="training set"/> <connect from_op="Logistic Regression" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="9.6.000" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="9.6.000" expanded="true" height="82" name="Performance" width="90" x="179" y="34"> <parameter key="manually_set_positive_class" value="false"/> <parameter key="main_criterion" value="first"/> <parameter key="accuracy" value="true"/> <parameter key="classification_error" value="false"/> <parameter key="kappa" value="false"/> <parameter key="AUC (optimistic)" value="false"/> <parameter key="AUC" value="false"/> <parameter key="AUC (pessimistic)" value="false"/> <parameter key="precision" value="false"/> <parameter key="recall" value="false"/> <parameter key="lift" value="false"/> <parameter key="fallout" value="false"/> <parameter key="f_measure" value="false"/> <parameter key="false_positive" value="false"/> <parameter key="false_negative" value="false"/> <parameter key="true_positive" value="false"/> <parameter key="true_negative" value="false"/> <parameter key="sensitivity" value="false"/> <parameter key="specificity" value="false"/> <parameter key="youden" value="false"/> <parameter key="positive_predictive_value" value="false"/> <parameter key="negative_predictive_value" value="false"/> <parameter key="psep" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="performance 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_test set results" spacing="0"/> <portSpacing port="sink_performance 1" spacing="0"/> <portSpacing port="sink_performance 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve advertising" from_port="output" to_op="Subprocess" to_port="in 1"/> <connect from_op="Subprocess" from_port="out 1" to_op="Cross Validation" to_port="example set"/> <connect from_op="Cross Validation" from_port="model" to_port="result 1"/> <connect from_op="Cross Validation" from_port="example set" to_port="result 2"/> <connect from_op="Cross Validation" from_port="performance 1" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator> </process>
Scott
1 - 1 of
11
Scott
Scott
Scott
