🎉Community Raffle - Win $25
Join and Win
Rapidminer connectivity with google cloud platform for nlp processing
User: "Divyem"
New Altair Community Member
Updated by Jocelyn
I am trying to use the google cloud platform api based integration to fetch the entity value, same I am able to fo with the below command in the command line
curl -X POST      -H "Authorization: Bearer $(API_KEY)"      -H "Content-Type: application/json; charset=utf-8"      --data "{\
  'document':{\
    'type':'PLAIN_TEXT',\
    'content':'Michelangelo Caravaggio, Italian painter, is known for\
              \'The Calling of Saint Matthew\'.'\
This gives me proper output response as below :-
  "entities": [
      "name": "Michelangelo Caravaggio",
      "type": "PERSON",
      "metadata": {
        "mid": "/m/020bg",
        "wikipedia_url": "https://en.wikipedia.org/wiki/Caravaggio"
      "salience": 0.82904786,
      "mentions": [
          "text": {
            "content": "Michelangelo Caravaggio",
            "beginOffset": 0
          "type": "PROPER"
          "text": {
            "content": "painter",
            "beginOffset": 33
          "type": "COMMON"
      "name": "Italian",
      "type": "LOCATION",
      "metadata": {},
      "salience": 0.13981608,
      "mentions": [
          "text": {
            "content": "Italian",
            "beginOffset": 25
          "type": "PROPER"
      "name": "The Calling of Saint Matthew",
      "type": "EVENT",
      "metadata": {
        "mid": "/m/085_p7",
      "salience": 0.031136045,
      "mentions": [
          "text": {
            "content": "The Calling of Saint Matthew",
            "beginOffset": 69
          "type": "PROPER"
  "language": "en"
Same I am trying to achieve using Enrich_data_by_webservice operator but everytime I do I am getting some error with various integration. Can anyone help me out. Below is the process I am using:-
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
      <operator activated="true" class="generate_data" compatibility="9.6.000" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34">
        <parameter key="target_function" value="random"/>
        <parameter key="number_examples" value="100"/>
        <parameter key="number_of_attributes" value="5"/>
        <parameter key="attributes_lower_bound" value="-10.0"/>
        <parameter key="attributes_upper_bound" value="10.0"/>
        <parameter key="gaussian_standard_deviation" value="10.0"/>
        <parameter key="largest_radius" value="10.0"/>
        <parameter key="use_local_random_seed" value="false"/>
        <parameter key="local_random_seed" value="1992"/>
        <parameter key="datamanagement" value="double_array"/>
        <parameter key="data_management" value="auto"/>
      </operator>
      <operator activated="true" class="web:enrich_data_by_webservice" compatibility="9.3.001" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="179" y="34">
        <parameter key="query_type" value="Regular Expression"/>
        <list key="string_machting_queries"/>
        <parameter key="attribute_type" value="Nominal"/>
        <list key="regular_expression_queries">
          <parameter key="text" value="(.*)"/>
        </list>
        <list key="regular_region_queries"/>
        <list key="xpath_queries"/>
        <list key="namespaces"/>
        <parameter key="ignore_CDATA" value="true"/>
        <parameter key="assume_html" value="true"/>
        <list key="index_queries"/>
        <list key="jsonpath_queries">
          <parameter key="entities" value="$..entities"/>
        </list>
        <parameter key="request_method" value="POST"/>
        <parameter key="body" value="{\&#10;  'document':{\&#10;    'type':'PLAIN_TEXT',\&#10;    'content':'Michelangelo Caravaggio, Italian painter, is known for\&#10;              \'The Calling of Saint Matthew\'.'\&#10;  },\&#10;  'encodingType':'UTF8'\&#10;}"/>
        <parameter key="url" value="https://language.googleapis.com/v1/documents:analyzeEntities"/>
        <parameter key="delay" value="0"/>
        <list key="request_properties">
          <parameter key="Authorization" value="Bearer ${API_KEY}"/>
          <parameter key="Content-Type" value="application/json; charset=utf-8&quot;"/>
        </list>
        <parameter key="keep_sensitive_headers" value="true"/>
      </operator>
      <connect from_op="Generate Data" from_port="output" to_op="Enrich Data by Webservice" to_port="Example Set"/>
      <connect from_op="Enrich Data by Webservice" from_port="ExampleSet" to_port="result 1"/>
    </process>
  </operator>
</process>
Have edited the  api_key value to some variable value above.
